RR Racing - USRS - Squeaky as a rusty gate!!
Well for the first 6 months, everyone was a happy camper, silent running and an amazing experience on steering feel.. Then all of a sudden it sounds like the car is part of a Stephen King horror movie, every time i cross any sort of imperfection in the road, be it bump or speed hump, sounds like a rusty gate blowing in the wind!! Like proper loud, "look at me" loud, cringe in your seat loud..
Lexus installed the bushings, and used the supplied lube on install, and on the last service we lubed them up as best as we could. But short of disassembling and trying the install again, what options are there on something like this?!
Look forward to hearing your feedback anyone who has had something similar
Lucky boy..
I guess what i should have asked, is what are some suggestions for some really good spray on lubricants which will last and provide some longer lasting results? Short of pulling it all apart, thats all i can think of doing.
Thanks in advance
I'm sorry to hear you are still having this issue. I know you have tried many things, please don't take offense if you have already thought of/tried these.
Do you drive on dirt or dusty roads frequently?
Spray lubricants like WD40 or other penetrants will actually thin and remove grease type lubricants. They can temporarily solve the problem but not last.
To get to the bottom of this I really think it will require removal of the brackets (I did the whole job in my driveway with hand tools in 1 hour, old ones out, new ones in, no alignment necessary) and then re-grease them with a heavy grease for polyurethane bushings. The stuff is THICK and sticky but it stays in place, is hard to wear off and lasts a long time. If it applies with a spray from a can, it will not be thick enough.
Thanks for all your suggestions, i think the easy solution is that i have to take them off, lube properly, then pop them back on..
Frustrating, as apparently the lube that comes with the kit was used..
Thanks again!
Thanks again!
Tech Info Resource
I wouldn't bet on the lube from Super Pro being used on the bushings. Super Pro is in OZ. They sell lube for poly bushings because they sell them by the truckload. There is no spray lube that will do more than stop the annoyance for a few minutes. The real stuff is thick as moose snot and isn't easily washed out or diluted except by trying to spray some weaksos lube in the bushing.
Yes, it sucks to have to remove them, but if you want to do it right, you have to rip off the condom.
Polyurethane bushings require maintenance!
Ahhh well.. thats how i got my two kids.. Nothing like some bareback on supermodels
Lowbux I have had many cars with super pro and Nolothane bushes and never had to maintain them NO squeaks, I just think Lexus didn't lube them enough or used the wrong grease. It only takes 2 slow hours to take them out and re lube with a 6 pack, Sunday job.
