IS350 F-Sport BBK clicking
Old 06-17-17, 02:54 PM
Offspring
Offspring's Avatar
Default IS350 F-Sport BBK clicking
06 is350 red 140K miles
2 days ago the fronts bbk started making the clicking sound shown in the video. I had my tech grease where necessary. He looked over it all and everything seems to be in place.
i went to lexus and the service writer refused to help because the BBK did not come from the factory installed , also because I had after market wheels.
ive read through plenty posts but they apple to stock brakes. Any advice is appreciated before I start ordering new friction rings and brake pads.
Im assuming this is brake related but I could be wrong. Not sure what else it could be.
Old 06-18-17, 04:42 PM
DryEye
DryEye's Avatar
Don't quote me but there are a couple of reasons why I think that your BBK would have a clicking noise:
Brake pads shifting in the brake calipers
Friction ring moving around on the hat
You could try and re-torque the caliper or re-bed the brake pads.
Try contacting Stoptech as they are the company that built/manufacture these BBK's. See if they have a remedy.
Post back with updates as this may help other owners with the F-sport BBK's that may encounter this issue in the future.
Old 06-18-17, 06:32 PM
Offspring
Offspring's Avatar
i will try the above and report back. Problem is I'm not even sure if it's the brakes or something with the suspension
Old 06-19-17, 01:58 PM
Gville350
Gville350's Avatar
My friend with a 2017 1LE Camaro has a similar clicking issue. From the factory, they have 2-pc rotors and alloy wheels. We've come to the agreement that it has to do with the disimilar metals of the rotor hat and that of the alloy of the wheels. To help curb any noise issues, my friend has been using anti-seize on the mating surfaces areas between the rotor hat and that of the wheel hub. NOT ON THE LUG NUTS.
Be sure to use a high-temp anti-seize that contains nickel, copper, etc etc.
Report back!
Old 06-19-17, 03:10 PM
Offspring
Offspring's Avatar
Report back!
again thank you for the input. I dropped off the car at the shop today and it will stay there till Tuesday of next week. It's an independent mechanic that I trust.
i have told him to rip apart the brake and inspect everything bolt by bolt and if need be order new bolts for the caliper/ rotor/hat mounting equipment.
i have advised ofnsolutions posted above. In fact he's reading this thread .
once again your input is greatly appreciated.
Old 06-20-17, 11:12 AM
Gville350
Gville350's Avatar
No problem! What is curious to me though is that yours happens at a dead-stop. My friend's only appears when driving at speed. VERY easily noticeable during our most recent auto-x; even have video of it with the noise being audible at a distance.
Old 06-20-17, 12:24 PM
MikeFig82
MikeFig82's Avatar
Do you have the AFS headlights? Isn't there a little type endlink for adjustments? I had a old gs400 with this. The little end link would click because it came loose.
Old 06-21-17, 06:31 AM
Offspring
Offspring's Avatar
i have 06. No afs headlights.
Old 07-07-17, 09:04 PM
Offspring
Offspring's Avatar
I finally heard back from stoptech. They are claiming the hard that's mounts the friction ring to the had should be replaced before trying anything else.
ill be replacing the pins next week.
Old 07-11-17, 02:11 PM
Gville350
Gville350's Avatar
Try the anti-seize trick. An almost "free" fix to do yourself.
Old 07-12-17, 11:41 AM
Offspring
Offspring's Avatar
it's being done today. I am stuck till Thursday to order parts from stoptech since the guy I'm dealing with is on vacation.
Old 07-13-17, 05:48 PM
Gville350
Gville350's Avatar
Let us know if that helped at all!
Old 07-13-17, 05:55 PM
Offspring
Offspring's Avatar
didn't work :/
on on the bright side stoptech wants me to take apart the friction ring and hat and clean it throughly . They are sending me a new drive pin kit to assemble them.
lets hope all goes well.
Old 07-14-17, 04:52 PM
trippy
trippy's Avatar
but the good thing is that ship looks seexy
Old 07-15-17, 07:33 AM
Offspring
Offspring's Avatar
haha thank you.
so here is what was explained after which I ordered drive pins for the rotor assembly. I will know Tuesday if they resolve the issue.
"The anti-rattle function is provided by an inconel bevel washer that acts like a spring. When you torque it down, it collapses, forming that spring, regardless of stacking tolerances from coatings, zinc plating, hat anodizing, etc. If you were ever to remove it, then reinstall it, there would be no spring pressure and the rotor would rattle. The M5x0.8mm screws will have stretched threads when removed, as the wicking loctite is extremely strong. They could fail, if reused. And the bushings will wear over time along the outside, also contributing to movement between the hat and the rotor (in unintended directions)."
Quick Reply: IS350 F-Sport BBK clicking
