OEM or after market pads & rotors? Rotor min spec?
Old 05-28-17, 09:34 PM
Modenaro
Modenaro's Avatar
Default OEM or after market pads & rotors? Rotor min spec?
Need to do brakes on my weekly driver SC300.
OEM pads are not too bad, checked LexusPartsNow.com (4) $106.00
But the rotors (If I need them seemed a bit much) (4) $360.00
Anyone have good luck with aftermarket brake parts on these?
Brand? Link? Source?
Not trying to cheap out on brakes.
(joke)
http://www.ebay.com/itm/Full-Kit-Rep...dYmoxJ&vxp=mtr
But this is just a fun xtra car in the stable.
Also, what is the Fr & Rear min. rotor thickness?
Thanks!
Old 05-28-17, 10:30 PM
Zerodrag
Zerodrag's Avatar
Assuming you have aftermarket wheels, you may be able to upgrade with an LS400 brake setup. Would be a good time to do so. If you don't want to piece it together yourself, there's someone in Craigslist that sells the entire kit in SoCA section.
Old 05-28-17, 11:04 PM
phphung
phphung's Avatar
you got a link to that guy? im interested!
Old 05-28-17, 11:44 PM
Modenaro
Modenaro's Avatar
Just looking for stock / stock equivalent performance.......... On this car.
At maybe less than OEM prices. If possible.
Old 05-28-17, 11:55 PM
Zerodrag
Zerodrag's Avatar
In that case, you can get OEM toyota pads off eBay for a little over $100 for F&R, and just generic replacement rotors for a bit more. Only thing I would recommend is to paint the hats because they will get surface rust developing on them if you don't (mine did).
Do a search on Craigslist for... "sc300 sc400 brake upgrade kit LS400 caliper"... and it should come up.
Modenaro (05-29-17)
Old 05-29-17, 05:42 AM
Modenaro
Modenaro's Avatar
Ebay is more $$$ than LPN.com on the oem pads?
Have not measured my rotors yet, anyone have the spec. ?
And its tough for me to just pick a rotor Co. without a recommendation.
They are probably all OK? Just the thought of warped rotors gives me the chills.......
Here are a few. $82 to $182 ...Thoughts?
$82.00 for (4) shipped?
http://www.ebay.com/itm/Front-and-Re...hY9M3R&vxp=mtr
This one is local to me.. http://www.ebay.com/itm/332214308297...%3AMEBIDX%3AIT
http://www.ebay.com/itm/Brake-Rotors...xX6Z-j&vxp=mtr
e-line brand..... $128 to $182 for the same parts? LOL LOL
http://www.ebay.com/itm/Brake-Rotors-FRONT-REAR-ELINE-O-E-BLANKS-Lexus-SC300-1992-1998-/351656894140?fits=Year%3A1994%7CMake%3ALexus%7CModel%3ASC300%7CSubmodel%3ABase%7CEngine+-+Liter_Display%3A3.0L&hash=item51e0625ebc:g:xWIAAOSwo4pYbFdE&vxp=mtr
http://www.ebay.com/itm/FRONT-REAR-P...VX6hxX&vxp=mtr
http://www.ebay.com/itm/FRONT-REAR-E...RYbK0o&vxp=mtr
Its good to look into this stuff. Found out yrs ago E30 M3's use 5 series rotors.
Saved quite a bit on that one. Buying 5 series rotors over the E30 M3 part.
Old 05-29-17, 09:41 AM
Blkexcoupe
Blkexcoupe's Avatar
Minimum spec should be engraved on the rotor. For OEM rotors:
Front is 30mm
Rear is 15mm
Modenaro (05-29-17)
Old 05-29-17, 09:47 AM
Modenaro
Modenaro's Avatar
Yep, just found it. Toss at 1.024 front .591 rear.
Old 06-02-17, 02:37 PM
Modenaro
Modenaro's Avatar
To end this one, went the budget route.
Centric Posi-Quiet Ceramic pads from Rock Auto and was able to turn the 4 rotors. ($15.00 ea)
$125.00 ....... brake job complete..........
Curious to see how these pads do. But only drive the car a couple/few thousand miles a year.
Old 06-03-17, 09:38 AM
RXRodger
RXRodger's Avatar
Never turn these rotors, most of the time you just end up with shimmy. Next time just replace them, they usually can be found for not a whole lot more than what you paid to have them turned. I ran Advance Auto cheapest rotors for a long time on a purely track car and they were fine for that, so for daily driving no problem with going that route. And since it is a daily driver just buy the mid grade at Rock Auto or your local parts store. If you were tracking this would be a different discussion. There are certain things you want to stick with OEM, but brakes is just not one of them.
Old 06-03-17, 10:30 AM
Modenaro
Modenaro's Avatar
Thanks, this one is weekly at best over daily. Still have .020 rear - .030 front left on the OEM rotors.
Have a 1990 E30 M3 and a 94 NSX that I go the opposite route on.
But on this one, am happy with what I have..... )
Good to know budget rotors worked for you. Thanks. Have looked, but never tried them.
Rock auto has some for this car that are in the $12-$15.00 range.
Said to be discontinued. But that stuff always scares me.
Turned the ones I had as they were true & had some meat left.
Will replace next time around.
Bocatrip
11-07-16 05:00 PM
OMAHA
23
02-10-15 04:11 PM
DavesLexus
08-11-12 10:16 AM
SPNinjA
Suspension and Brakes
04-20-10 08:32 PM
mzeitlin
23
07-20-06 09:56 AM
Quick Reply: OEM or after market pads & rotors? Rotor min spec?
