Catalytic Converter
Old 05-26-17, 07:18 PM
Engine11
Engine11's Avatar
Default Catalytic Converter
Do universal catalytic converters work
Old 05-29-17, 05:26 AM
Rock-a-Lex
Rock-a-Lex's Avatar
Yes, they did for me. My old ones were from Eastern Catalytic. Direct bolt on...
Of course now I have test pipes from Megan Racing to help move the exhaust along for my FI setup. You need downstream O2 simulators though to trick the car's emission monitors though if your planning on passing inspection with these bad boys. I've passed the strict NYS inspection for the last 4yrs. No check engine lights.
They're $100/ea but you need to get them for a 2002-2010 SC430. They fit the '98-'00 GS400. Not sure about the 430 though. Good luck
Old 05-30-17, 09:03 AM
sakataj
sakataj's Avatar
generally... but they are more of a bandaid as they hide the issue since you use a o2 simulator/o2 fouler to fool the ECU
a few things, 1 the GS430 has 3 cats while the GS400 has 2 and a resonator, i dunno what the Gs300 has as i dont own one. so if its your front cats the one rock posted should be fine
get them here
http://www.meganracingperformance.co...-p-469090.html
and NOT from ebay
http://www.ebay.com/itm/MEGAN-RESONATOR-EXHAUST-TEST-PIPE-FOR-02-10-LEXUS-SC430-Z40-3UZ-3UZ-FE-V8-4-3L-/111782434785?hash=item1a06c097e1:g:fKsAAOSwMmBVmyoY&vxp=mtr
they also make a section that bolts from the front 2 cats and deletes the 3rd cat BUT you will def need a O2 fouler or O2 simulator here if not for the front ones also
http://www.ebay.com/itm/Megan-Racing-304-Stainless-Steel-Downpipe-for-Lexus-SC430-2001-05-V8-4-3L/282473113248?_trksid=p2047675.c100623.m-1&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D40130%26meid%3Dbee619a0c8bd4e438f4c361c95bbb5a2%26pid%3D100623%26rk%3D1%26rkt%3D1%26sd%3D111782434785
also if its for a gs430 magnaflow has a better looking middle piece WITH a cat on it
https://www.tunersports.com/magnaflo...21_p50225.html
Old 05-30-17, 03:40 PM
khoi714
khoi714's Avatar
So I can use the megan racing test for 02-10 test pipe and down pipe for my 03 GS430. Because I contact Megan racing and they said it won't fit. But you are saying it will? If it does then I will get them. Thanks!
Old 05-30-17, 04:20 PM
firelizard
firelizard's Avatar
The Y-pipe with 3rd cat Magnaflow part 24321 and 49085 do not fit the GS430, they're too short because they're made for the SC430. I showed this to Magnaflow and they did not care. Mounting at the front of the system is the same though so I imagine the 2 front cats will fit as intended.
Old 06-01-17, 10:47 AM
sakataj
sakataj's Avatar
no im not saying anything except showing you were to find parts that are made for it
interesting... you verified this? thats a shame cause i think my 3rd cat maybe going bad and i was hoping to use this....
Old 06-01-17, 05:50 PM
firelizard
firelizard's Avatar
Yes. I've posted about it here before. I had to have an extension made.
sakataj (06-14-17)
Old 06-10-17, 10:23 PM
snakehead
snakehead's Avatar
Will these work for my 1998 GS400 ,Yesterday I just thru an engine code on a bad cat ..Bank 1 , Will these throw a engine light ??
Old 06-12-17, 07:03 AM
MotoCARR
MotoCARR's Avatar
In to hear what some GS300 owners have done for this too
AM21GS400
02-01-20 07:25 AM
kevin.tran
04-28-10 10:44 PM
chums
Performance
07-13-09 08:46 PM
CCC-TT
Performance & Maintenance
01-03-09 05:51 PM
BCSC300
08-09-04 07:51 PM
Quick Reply: Catalytic Converter
