Are all four wheel bearings on the 2011 ES pressed?
Old 05-26-17, 06:18 PM
albodan
albodan's Avatar
Default Are all four wheel bearings on the 2011 ES pressed?
I need to figure out which one needs to be replaced, so I wanted to know if there are any differences?
Old 05-26-17, 07:36 PM
jagtoes
jagtoes's Avatar
Are you talking about the front wheel bearings or the rears. In the case of the fronts they are pressed into the hub assembly and usually the hubs are replaced as a unit.
Old 05-26-17, 07:48 PM
albodan
albodan's Avatar
If I replace the front bearings hub assembly will I have to use a machine press? You got any idea how to replace them?
I watched a video by chrisfix on bearings that are not pressed specifically this one:
https://m.youtube.com/watch?v=fe_WtKIKlYA
Will the process be anything like this?
Old 05-26-17, 07:59 PM
nevernu
nevernu's Avatar
maybe this is useful
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old 05-27-17, 07:55 PM
PoorES
PoorES's Avatar
The front are pressed in and the rear are sold as part of a bolt-on assembly. For the fronts, get a Front Wheel Bearing Kit similar to the Astro Pneumatic Tool 78825. For the rear, you may need a slide hammer if the bearing is seized in.
Old 05-28-17, 12:58 AM
chuyrobles
chuyrobles's Avatar
First figure out which bearing needs replacing. If the front, this may help.
https://www.clublexus.com/forums/es-...ml#post9592140
nevernu (05-28-17)
Old 05-28-17, 04:59 AM
nevernu
nevernu's Avatar
nice I'll bookmark that one
ubaratham
07-11-18 09:11 AM
river
RX - 1st Gen (1999-2003)
04-03-16 10:03 AM
sivikvtec
Suspension and Brakes
03-13-10 06:51 PM
jip
Maintenance
08-31-06 04:48 PM
Quick Reply: Are all four wheel bearings on the 2011 ES pressed?
