2008 GX470 using coolant
I bought this GX a few months ago and when I bought it I noticed the coolant level was down below the L line in the reservoir. Last week I finally got a hold of some Toyota ling life coolant and filled it to the F line and when I checked it one day later it was back down below the L line! What's weird is I don't see any leaks and I would think if it was a head gasket issue it would keep consuming coolant until the reservoir was completely empty but there is always a an inch or so in the bottom of the reservoir Any ideas? This truck has perfect service records and 144,000 miles. II hope I didn't buy a lemon any help would be appreciated.
was the water pump replaced at the timing belt service? its possible there is a leak and its burning off a hot surface, radiators are a frequent replacement item on these trucks.
Went and picked up the GX from my wife to take it to autozone to rent a radiator pressure tester, before I left her work I filled up the reservoir to the F level. When I got to autozone (2 miles) I looked under the truck and this is what I found. So I'm thinking I need a new radiator.
chest. Another test is; if your cabin heater works fine that is good indication water pump is working good. Sounds
like cap is not keeping the pressure losing collant due to old age if it is original one. Hot engine can boil of fcoolant
without trace some times. Pressure tester also can test cap.
I pulled the shroud to get to get a closer look. I don't think it's the cap, looks to be coming from the top area where a crimp came loose. It's leaking so high up on the radiator I guess I didn't loose too much coolant which explains why it hasn't overheated?
So I'm having a hard time sourcing a Koyorad. What are some other reputable replacement brands? I've found a Denso for a reasonable price but don't know of their quality.
Get the Denso.
I ordered the desno, upper and lower hose, thermostat and gasket. Plus 3 gallons of xerex asian which I know is not recommended by Lexus but I've read it's a good cheaper alternative.
