Display current gear?
Old 05-23-17, 09:10 AM
guxu
guxu's Avatar
Default Display current gear?
Is there a way to display the current gear? I have a regular 2017 RX.
Also, does RX have audio alert for Blind Spot?
Old 05-23-17, 09:42 AM
mcomer
mcomer's Avatar
Draw the shifter to the left and the Dash display with change from "D" to "M4" or M1" and show your
current gear. Push forward or back to up shift or down within the limits set by the electronic trans.
BSM displays the yellow icon in the outside mirror without a tone when a car is behind and beside
you at speeds above 15 mph. No need for a warning while stopped in traffic. The same system
provides Rear Cross Traffic Alert when you are in reverse (at any speed) and does add a
chime to the mirror illumination. The RCTA range can be as much as 65 feet if the oncoming
car is moving quickly (manual says 18 mph) .
Old 05-23-17, 12:52 PM
guxu
guxu's Avatar
So for BSM, there is no audio alert when turn signal is on, just a blinking icon. To me, it is a bad design.
Old 05-23-17, 01:04 PM
dchar
dchar's Avatar
No audio, just visual alert. You should be looking at the side mirror when changing lanes anyways.
Old 05-23-17, 03:50 PM
mcomer
mcomer's Avatar
Solid icon when they are in the zone, if you put on your turn signal to that side it goes
to a blink rate faster than the turn signal. The difference between the sound of the turn
signal and the visual of the yellow icon is very attention grabbing and should encourage
you to glance at the mirror...
Old 05-24-17, 02:26 AM
ggebhardt
ggebhardt's Avatar
Would not hurt for Lexus to provide an audible alert.
satnav (05-25-17)
Old 05-24-17, 03:59 AM
aznkorboi
aznkorboi's Avatar
I think it's badly designed too. Even an audio alert or a vibration of the steering wheel! SO sad.
Yes, look at the side mirrors but sometimes in mid day you can barely see the orange (same color as the sun) icon.
Old 05-24-17, 06:36 AM
Mors
Mors's Avatar
i don't think it's a bad design necessarily. There are other times the BSM will flash. For example, if you're in a double turn lane with your blinker on and the light turns green. You start moving and the cars next to you start moving. You aren't changing lanes, but BSM doesn't know that. Would you want an audio alert bugging the crap out of you every time you do that? No....I didn't think so. It'd be nice if it could read your mind and could tell if you were about to change lanes or not, but it can't, so I'll live with it flashing at me.
Here's another example:
https://www.edmunds.com/hyundai/sona...ad-habits.html
Old 05-24-17, 07:55 AM
Gibster
Gibster's Avatar
Thumbs down
Considering how often the BSM activates it would drive me crazy if it beeped along with the visual indicator.
Old 05-24-17, 08:26 AM
ggebhardt
ggebhardt's Avatar
I am pretty sure my Mercedes and Porsche both had an audible BSM alert so they were able to work it out and I never remember it driving me crazy.
Old 05-25-17, 06:33 AM
satnav
satnav's Avatar
for audiable alerts they only chime when the signee is activated on most cars. That would be helpful with signal on and blindspot
jdanielca
02-12-19 08:09 PM
nas2344
RX - 4th Gen (2016-2022)
05-26-17 12:58 PM
elba123
RX - 3rd Gen (2010-2015)
21
12-14-15 12:52 PM
jamodeo
03-14-15 06:01 AM
pumper
01-27-06 03:14 AM
Quick Reply: Display current gear?
