Check engine, trac off and vsc light on at same time, have error codes! read on...
Old 05-22-17, 11:45 PM
DIYDD
DIYDD's Avatar
Post Check engine, trac off and vsc light on at same time, have error codes! read on...
I seriously need your help. A P0420 error code popped up yesterday and my emissions inspection is next month AGGH! I love my 2002 Lexus ES300 (128K miles) and I just don't want to let it go if I have to pay a crapload of money to replace fix the cat on Bank 1.
I want to mod an O2 sensor before bringing it into a dealer. BUT I have no clue which 02 sensor to mod.
Q: In your professional opinion, which O2 sensor do you think I should mod (please see attached photo)?
Ps Thank you for your professional advice in advance!
DIYDD
Attached Thumbnails Check engine, trac off and vsc light on at same time, have error codes! read on...-2002-lexus-es300-engin-diagram-4-question-marks.gif
Old 05-23-17, 05:20 AM
HomerJay
HomerJay's Avatar
The upstream O2 sensor that needs to be replaced is the front one (radiator side). It is recommended to buy an OE "plug and play" replacement such as Denso to avoid problems. To help ease removing the old one, spray the threads ahead of time with PB Blaster or equivalent.
Old 05-23-17, 08:03 AM
DIYDD
DIYDD's Avatar
Question this one?
OMG thank you so much HOMERJAY for your professional advice. Do you mean the "Heated Oxygen Sensor Bank 1, Sensor 2" or "Heated Oxygen Sensor Bank 2, Sensor 2?" (Please see attachment for your convenience)
Ps HomerJay, I am trying to do what this
video is instructing.
I think the vid provided above for your reference will work when you click the picture aboveQ: What do you think?
Thank you so much!
Frustrated ;/
DIYDD
Attached Thumbnails Check engine, trac off and vsc light on at same time, have error codes! read on...-2002-lexus-es300-engin-diagram-heated-o2-sensor-bank-1-sensor-2.gif
Old 05-23-17, 09:21 AM
HomerJay
HomerJay's Avatar
Sorry, I am not able to view your pictures or video. You need an upstream (which means before the cat.) bank one O2 sensor. BTW I am not a professional mechanic, but happy to help.
Old 05-23-17, 09:56 AM
nsghtbrwry
nsghtbrwry's Avatar
Actually that's incorrect - you need to deal with the downstream sensor. P0420 is something like "catalyst below efficiency threshold." The upstream O2 sensors are used by the ECU for closed-loop fuel operation. The ECU compares the downstream sensor to the readings from the upstream sensors to determine if the catalyst system (any of the three cats) are not performing to spec.
"Modding an O2 sensor" - an O2 sensor spacer on the downstream sensor - and obviously I'm not condoning this (and note that it will fail visual if your state does that), such as
Amazon Amazon
...will pull that sensor out of the exhaust stream and fool the ECU into thinking everything is fine. Then your car will pass smog as long as the cats aren't degraded to the point that it fails the sniff test.
Old 05-25-17, 03:00 AM
DIYDD
DIYDD's Avatar
Default Downstream?
"Modding an O2 sensor" - an O2 sensor spacer on the downstream sensor - and obviously I'm not condoning this (and note that it will fail visual if your state does that), such as https://www.amazon.com/Blox-Racing-B...ct_top?ie=UTF8
nsghtbrwry - thank you so much for the post! On the picture / diagram provided above, whicj one is the down stream sensor for a P0420 "catalyst below efficiency threshold Bsnk 1?"
Ps Several mechanics quoted a minimum of a $1000 and the car is running perfectly.
Thanks for your professional help.
DIYDD
Old 05-25-17, 07:38 AM
nsghtbrwry
nsghtbrwry's Avatar
You need to address both downstream sensors (Sensor 2 on each bank). I'm unfamiliar with the post-2001 1MZ-FE motors, since my newest one is an '01 and only has one downstream sensor, not two.
(Also I'm not a professional)
Old 05-25-17, 09:11 AM
DIYDD
DIYDD's Avatar
Default sensor?
nsghtbrwry - Do you mean botb the Heated Oxygen Sensors (Bank 1 and 2, Sensor 2) to address the P0420 error code? My aplogies for my ignorance.
DIYDD
Old 05-25-17, 07:17 PM
nsghtbrwry
nsghtbrwry's Avatar
DIYDD
Yeah, both downstream. P0420 won't be specific as to which bank is not catalyzing efficiently AFAIK (but keep in mind I only have 1MZ's with a single downstream sensor).
Old 07-22-19, 06:15 PM
JZielieke
JZielieke's Avatar
Hello,
I was curious if you found a solution as I am having the same exact issue.
Thank you
Beingreen89 (02-19-24)
Old 10-02-19, 09:06 PM
omar804
omar804's Avatar
i have 2002 es300 with codes of p0420 and p0430 that i can't get rid of , any feedback would be appreciated.
Old 10-02-19, 10:11 PM
Richardsr
Richardsr's Avatar
If you have a code on one bank/sensor.... Swap sensors to see if the problem follows the suspected bad one. If the code doesn’t follow the suspected sensor, that CAT is bad. If it follows the suspected sensor, the sensor is bad.
CPALex
02-20-20 08:47 AM
ismike420
GX - 1st Gen (2004-2009)
07-18-14 06:48 AM
samk425
07-17-14 12:22 PM
g35c
11-23-10 12:33 AM
igbeserk
05-30-10 09:31 PM
Quick Reply: Check engine, trac off and vsc light on at same time, have error codes! read on...
