MA TE37 Ultras 19x9.5 +35, 19x10.5+32 Diamond Black 5x114
Up for sale, a set of fairly new genuine TE37 Ultras.
Specs:
Color: Rays Diamond Black
PCD: 5x114.3
19x9.5 +35
19x10.5 +32
Comes with low profile, color matched center caps.
I have >1000 miles on them. Selling because I am not a fan of the engraved ring around the circumference of the wheel. One rear wheel has a a very light clear scratch, easily polished out. The front wheels have been coated with Ceramic Pro9H coating, I will take care of the rear when I have a buyer and before shipping.
Asking $3700 plus shipping including tires; Bridgestone RE-11 245/35 & 275/30
**Moderator, I have a vouch, RCB. Let me know who I should direct him to.
Specs:
PCD: 5x114.3
19x9.5 +35
19x10.5 +32
PM sent with vouch.
These TE37s are beautiful and are basically brand new. I installed them at the end of last season and I'm sure they haven't had much use. I know it took a long time to get these from Rays as all there wheels do so whoever buys them just saved themselves that painful step plus the process of picking and mounting tires.
I will try to grab some face photos tomorrow. The fronts are Face 3 and the rears are Face 4, which is the deepest concavity Rays produces in the Ultra.
I am running;
BC Coilovers with Swift Springs 12/16k springs
Figs Engineering Upper and Lower Links (2 Upper, 2 Lower and Trac Links)
Rear quarters were rolled
And absolutely no rubbing at all. When I initially had the suspension work done we weren't sure how the fitment was going to be so we wanted to be safe and I had the rear camber set at -3.2. I have plenty of room between the quarter and wheels. The car will be getting realigned and I intend to have the camber pulled. I believe I have more than enough room to fit 295s as is without rubbing.
All suspension work were performed by CL member RCB.
I am running;
I am at -2.5 but it was set at that for handling purposes not so much for fitment. I do have the quarter panel lips rolled. I have zero rubbing and had plans to go either 285 or 295 which I believe wouldn't be problem. Keep in mind that I am running all of Figs rear links and arms which allows me to bring the hub in a little more.
Fpsboon (09-10-17)
