heat not getting hot water control valve arm does not move 1995 ls 400 what to do?
Old 05-19-17, 12:59 AM
Aldiggy
Aldiggy's Avatar
Default heat not getting hot water control valve arm does not move 1995 ls 400 what to do?
no heat fans work dash controls seem to work water control valve not moving I think cable goes to driver side of middle console are there fuses for this system and what else to check
Old 05-19-17, 06:53 AM
Scraape
Scraape's Avatar
impressive you crammed all that in to one sentence
Old 05-19-17, 09:35 PM
Losiracer2
Losiracer2's Avatar
Do a proper bleed and fill on your coolant. You're probably low and have an air pocket somewhere in the system. Add coolant to the fill hole in the front middle of the engine, just behind the thermostat NOT through the radiator cap/coolant reservoir.
Old 05-22-17, 07:12 AM
billydpowe
billydpowe's Avatar
the heater control valve should move when you switch from hot to cold, if not get another one.. easy fix.
Attached Thumbnails heat not getting hot water control valve arm does not move 1995 ls 400 what to do?-hcv.jpg
Old 05-22-17, 09:45 AM
Banshee365
Banshee365's Avatar
Assuming the valve itself is not locked up, that's sort of like saying: Your tires should turn when the transmission is in drive. If not, replace your tires. No?
Old 05-22-17, 02:24 PM
billydpowe
billydpowe's Avatar
NOT assuming...... I said the heater control valve should move when you switch from hot to cold .. and this is the correct movement...
Old 05-22-17, 03:11 PM
Banshee365
Banshee365's Avatar
Have you seen one lock up? It would sure be easy to disconnect the drive cable from the valve and see if the cable moves as it should when not connected. It allow manual movement of the valve as well. I'll have to look at the logic for the water valve as most vehicles I've seen with a water valve only close it in the max cool or recirc mode. I've never noticed how the LS400 does it. I do know that I hear burbling in the heater core after filling an empty cooling system WITHOUT the heat on.
Old 05-22-17, 04:07 PM
billydpowe
billydpowe's Avatar
dont do any extra work on my account, I haven't "worked" in about 15 years on mine, and I'm 83 now and FORGET a lot.... I have only replaced one HCV on a LS, and that was when we raised the motor to install MM's and didnt move the HCV and busted it... hello salvage.. and you are right, you can slip off the cable and move the lever and go from there..
Old 05-22-17, 06:21 PM
timmy0tool
timmy0tool's Avatar
you could also have a disconnected cable or the air mix motor that moves that cable/valve is bad.
Old 06-14-17, 08:30 PM
Aldiggy
Aldiggy's Avatar
Thanks for so many responses guys it turned out to be a couple of issues no thermostat installed one vented and bleed cooling system after refilling used wd 40 lubricant at pull wire for valve at engine firewall and changed cabin air filter looked as if never changed air was not able to pass thru filter chamber totally blocked replaced filter . the car has heat now but still behaves like there is air some where up top,heat performs great at highway speed not so much around town stop and go. coolant valve should have lower mount point I think going to change old reservoir cap for better pressure and re bleed with car parked on an up hill pitch hope that cures it totally
j400
07-24-17 02:18 PM
xt1956
Performance & Maintenance
06-13-16 09:18 PM
89supra884
08-18-12 09:32 PM
sc3dreamz
01-24-08 02:02 PM
rybikowsky
09-14-02 12:37 PM
Quick Reply: heat not getting hot water control valve arm does not move 1995 ls 400 what to do?
