Transmission flush
Old 05-15-17, 01:11 PM
primavera
primavera's Avatar
Default Transmission flush
Hi everyone,
I'd like to switch to AMSOIL Signature Series Synthetic Automatic Transmission Fluid (blue cap bottle) instead of Toyota's ATF WS fluid.
My question is how many quarts / liters of fluid do I need to buy to perform this flush? Can anyone chime in?
Thanks for your help.
User 122922 (08-04-21)
Old 05-16-17, 08:55 AM
SeanO
SeanO's Avatar
I just had my transmission fluid replaced this past week by Lexus and I was told it was about 4L or 1 gallon.
primavera (05-16-17)
Old 05-16-17, 12:50 PM
primavera
primavera's Avatar
Thanks SeanO,
Is your car 6 Speed manual or automatic? RWD or AWD?
I guess I'll contact my mechanic and ask him how much exactly is needed for this procedure. He says he does this regularly to a lot of taxi cars.
Thanks for your input man.
Old 05-16-17, 05:43 PM
leoferus
leoferus's Avatar
I flush my transmissions with 12 quarts of World Standard every 50k.
Old 05-16-17, 07:06 PM
LXMEUP
LXMEUP's Avatar
Why you guys are using the word 'flush' I'm assuming you're dropping the pan and changing that oil?
A full flush using the proper pumps would be a LOT more than 4 L
Old 05-16-17, 08:16 PM
primavera
primavera's Avatar
There are two methods:
Drain and fill shown in the video below and "flush" by using transmission exchange fluid machine.
Old 05-16-17, 10:20 PM
primavera
primavera's Avatar
How to measure transmission fluid level between 104 and 113°F or (40 and 45°C) using handy ScanGauge II
Old 05-17-17, 07:51 AM
SeanO
SeanO's Avatar
Originally Posted by primavera
Thanks SeanO,
My car is 6 speed auto and RWD.
My car had the fluid flushed - so it was pump in and pump out temperature controlled the entire process.
Old 05-23-17, 05:13 PM
ponteley
ponteley's Avatar
Have anyone see exactly where did tech hook up BG machine during flush ? My mechanic have BG machine, but he never done sealed transmission like 350, can't fing cooling line to attach it.
Old 05-23-17, 08:33 PM
Brian7
Brian7's Avatar
What does a full flush cost from the dealer?
Old 05-23-17, 08:49 PM
ponteley
ponteley's Avatar
$230 here in Chicago
Old 05-23-17, 09:44 PM
Zmon
Zmon's Avatar
Depends on the dealer really. I think I paid about $300 at Lexus of Memphis.
McGrath by any chance?
Old 05-24-17, 11:43 AM
ponteley
ponteley's Avatar
Arlington Hights
Old 05-24-17, 03:52 PM
See5
See5's Avatar
Drain and fill is safe. ATW WS 1 Gallon is needed.
You should feel smoother downshifts. I do it whenever I start hearing hard shifts and they go away after fluid change. Usually every 30k miles. It is not synthetic and you must change it to maintain the transmission.
Old 05-24-17, 07:33 PM
leoferus
leoferus's Avatar
24mm fill plug on driver's side. Pressure test port on passenger side.
Quick Reply: Transmission flush
