New CL Vendor R1 Concepts| High Carbon Alloy Geomet Rotors & Brake Pads!
Sponsor
R1 Concepts- High Carbon Alloy Geomet Rotors!
We're happy to introduce to you all our new High Carbon Alloy Geomet rotors! These rotors are a new and improved version of our "Premier Series" rotors. Manufactured for european and heavy vehicles, our High Carbon iron formulations enhances noise dampening characteristics, while providing high strength, and increased thermal conductivity compared to standard discs, which increases durability. Each rotors is engineered to match the OE vane configuration, including OE split-core technology to ensure proper and maximum heat dissipation. Additionally, all cores are dipped with a specifically formulated paint in order to provide a smoother finish inside the vane structure. The smooth finish will improve air flow as well as reduce the amount of machining required in order to properly balance the finished rotor during the mill-balancing process.
Geomet Finish
After all the machining processes are completed, each rotor passes a 100% electronic inspection station that measures over 20 attributes to ensure that each rotor meets OE specifications. This further guarantees that each and every rotor delivered to you is trouble free. Finally, we apply a genuine GEOMET finish throughout the entire part, which promises to deliver superior corrosion protection. The GEOMET coating is processed dry, shipped dry, and ready to install without any additional preparation.
-Ready to install- No additional preparation needed. Saves time and money during installation process.
-Superior Corrosion Protection- Provides excellent cyclic corrosion performance when tested according to automotive manufacture's test methods incorporating heat, salt spray (withstands 400 hours), and humidity (SAE J2334, GMW 14872, Ford CEPT: 00.00-L-467, Asian CCT).
-Environmentally Friendly: Meets the following regulations: Environmental Protection Agency (EPA), Chrysler CS-9003, General Motors GMW 3059, Ford WSS-M99P9999-A1 (Hex 9), the EU Directives on End of Life Vehicles (ELV) and Electrical Equipment (RoHS).
Fine-Turned
The castings are sent to our state of the art machining facilities, where each rotor is machined to the tightest tolerances available in the market today. We can guarantee specifications of .010mm disc thickness variation (DTV) and .050mm maximum lateral runout. Though in practice, we regularly achiece .007mm DTV and .025mm maximum lateral runout. Then, the rotors are fine-turned to a maximum of 1.6 RMS. The objective of these strict tolerances is to create the smoothest possible finish, which improves initial break-in due to the increased contact between the pad and the rotor.
2013-2018 GS350 AWD & RWD Without F Sport
FT/RR CARBON ALLOY OEM GEOMET ROTORS: $225 SHIPPED
FT/RR CARBON ALLOY SLOTTED GEOMET ROTORS: $330 SHIPPED
FT/RR CARBON ALLOY DRILLED & SLOTTED GEOMET ROTORS: $350 SHIPPED
FT/RR CARBON ALLOY DRILLED GEOMET ROTORS: $340 SHIPPED
FRONT CARBON ALLOY OEM GEOMET ROTORS: $145 SHIPPED
FRONT CARBON ALLOY SLOTTED GEOMET ROTORS: $210 SHIPPED
FRONT CARBON ALLOY DRILLED & SLOTTED GEOMET ROTORS: $220 SHIPPED
FRONT CARBON ALLOY DRILLED GEOMET ROTORS: $220 SHIPPED
2013-2018 GS350 RWD F Sport (1-Piece Full Cast Front Rotors)
FT/RR CARBON ALLOY SLOTTED GEOMET ROTORS: $600 SHIPPED
FT/RR CARBON ALLOY DRILLED & SLOTTED GEOMET ROTORS: $620 SHIPPED
FRONT CARBON ALLOY SLOTTED GEOMET ROTORS: $480 SHIPPED
FRONT CARBON ALLOY DRILLED & SLOTTED GEOMET ROTORS: $490 SHIPPED
Geomet Finish
Fine-Turned
__________________
Kevin- Sales Representative
R1 Concepts Inc.- Performance Brake Parts
Kevin@r1concepts.com
888-712-6623 Ext. 7022
Sponsor
According to our R&D dept, no one on the market offers these rotors other than OEM. We're currently in the process of making our own casting since it's a 2-piece rotor. We should probably have these available by the end of the year!
__________________
The following 2 users liked this post by R1Concepts:
LatinLS430 (05-10-17),
Nasrul3698 (05-14-17)
if you guys are able to develop fsport 2-piece rotors cheaper than the oem ones and offer slotting/drilling, you'll have so much business from CL.
Eazy1234 (11-07-21)
Sponsor
I'll definitely relay this message to our R&D dept to try to get these 2-piece rotors hopefully made for you guys!
__________________
you guys wouldn't regret a slight bit after making those 2 piece rotors. Please make it ready faster!!!
R1Concepts (05-15-17)
Sponsor
At the moment there's no update. We will probably have it available at the end of the year or the beginning on 2018.
__________________
harper7 (08-24-17),
Nasrul3698 (08-25-17)
