Manifolds comparison between ISF and RCF
Old 04-29-17, 09:43 AM
LegendaryQ
LegendaryQ's Avatar
Default Manifolds comparison between ISF and RCF
Hello all,
i hope everyone is doing alright.
i was wondering if the manifolds for these two cars are interchangeabl! Is it possible for me to install an ISF's OEM manifold into my RCF?
It might be a silly question, but id apreciate your answer
Old 04-29-17, 12:17 PM
flowrider
flowrider's Avatar
Received 1,826 Likes on 1,288 Posts
Not sure, but looks like - Maybe
Lou
File Type: pdf
Old 04-29-17, 01:01 PM
jspecvtec
jspecvtec's Avatar
I think maybe? If aftermarket header fits both isf/rcf?
Old 04-29-17, 01:27 PM
flowrider
flowrider's Avatar
^^^^Headers bolt right up. The clearance differences are due to the "stuff" around the side of the engine. But, that really makes nonevermind about the intake manifold.
Lou
Old 04-29-17, 01:44 PM
mjeds
mjeds's Avatar
it might bolt up, but it won't work the same, it will require tuning, the chambers are larger as is the throttle body on the RCF.
Old 04-29-17, 06:52 PM
LegendaryQ
LegendaryQ's Avatar
Comparison
Thank you for the quick reply.
Lou, it seems that the LH side are identical, however the RH side look different.
The cats sizes seem very similar tho, i dont think they require tuning? Im just saying im not an expert.
Old 04-29-17, 07:43 PM
flowrider
flowrider's Avatar
I thought you were talkin' INTAKE manifold, not exhaust Yes, they bolt right up. However, the RCF's outlet is larger than the ISF:
Flange Exit size Information:
ISF - 60mm (2.4")
RCF - 65mm (2.6")
And no, No tuning would be required.
Lou
The following 3 users liked this post by flowrider:
LegendaryQ (04-30-17), stopdrpnro (07-13-23), WhyHateTho (04-03-23)
Old 04-29-17, 11:01 PM
LegendaryQ
LegendaryQ's Avatar
ISF - 60mm (2.4")
RCF - 65mm (2.6")
Lou
haha sorry for the confusion there i shouldve mentioned it
im planning to replace mine (damaged) with an IS F's, would you recommend doing that?
The dealer's parts are quite expensive here
Old 04-30-17, 05:02 AM
flowrider
flowrider's Avatar
^^^^While the manifold will bolt up to the engine, the ISF exhaust manifold will not bolt up to your exhaust system because of the smaller outlet. The exhaust flange would need to be cut off and replaced and of course, a new gasket.
And, over time the ISF manifolds have been shown to crack. The RCF manifolds have not been out long enough to see if thats also the case. I sold my manifolds to another ISF owner who had a cracked manifold.
Lou
Old 04-30-17, 07:37 AM
ROK
ROK's Avatar
One dude's bright idea, another man's trash
Old 04-30-17, 12:16 PM
LegendaryQ
LegendaryQ's Avatar
Lou
The damaged part is the cats.. id probably cut them and then do some welding to get everything in place.
Old 04-30-17, 01:09 PM
mjeds
mjeds's Avatar
ebay has several totaled RCF's, might be easier to just find an RCF manifold from a take off.
Old 04-30-17, 03:19 PM
ba2sy
ba2sy's Avatar
You got a messed up CC on the RCF Headers?
How did you know?
And how did that happen?
Old 04-30-17, 08:54 PM
LegendaryQ
LegendaryQ's Avatar
ive been digging for some time and all i found was a GS F engine with the manifold ... still waiting for the seller to reply back
How did you know?
Yea its bascically gutted ... bad decisions
Old 04-30-17, 09:27 PM
Manh3
Manh3's Avatar
^^^ what negatives are you experiencing if you don't mind sharing so others won't make the same mistake. Thanks
Quick Reply: Manifolds comparison between ISF and RCF
