AC Intermittent issue - replaced High pressure switch
Old 04-28-17, 11:55 AM
biacs
biacs's Avatar
Default AC Intermittent issue - replaced High pressure switch
Guys,
I just wanted to more or less post a placeholder. I had my local garage, order and replace the AC high pressure switch - its a known problem. The refrigerant has to be evacuated since its a direct switch. Its super easy to access - right in front of the radiator. But parts and the service ran me about $130.
I let it go for a couple years, time to stop being so cheap!
Old 04-29-17, 04:18 PM
StanVanDam
StanVanDam's Avatar
My 2002's only AC problem was corrosion of the high pressure side line going to the rear AC system (only UL package has a rear AC unit), causing refrigerant to slowly leak (and manifesting as intermittent AC) until enough refrigerant leaked to cause the AC system to not cool at all.
4mula_J87
06-21-19 04:27 PM
biacs
05-12-17 04:48 AM
gvcenter54
RX - 1st Gen (1999-2003)
12
07-28-14 04:10 AM
gleighlady
03-19-11 03:03 AM
2JZPOWER
19
09-14-07 03:32 PM
Quick Reply: AC Intermittent issue - replaced High pressure switch
