Door is closed. But dash says otherwise
Old 04-22-17, 08:58 PM
JuiceIam
JuiceIam's Avatar
Default Door is closed. But dash says otherwise
Recently my SC has been thinking my driver door is open when its not. Which is annoying obviously for a few reasons. And also because my alarm won't arm.
I have done the standard things like lube the latch and what not.
I have looked around to see if i can find a switch that would be tripped by an open door and I don't see anything obvious.
Any help would be much appreciated.
Old 04-24-17, 04:09 AM
Bdub215
Bdub215's Avatar
Pbblaster the latch and slam that ***** a few good times.
Old 04-24-17, 05:21 AM
gerrb
gerrb's Avatar
If your door switch is good (pressing it firmly by hand and cluster light is still on) , then it is more likely you have a bad Integration Relay found at the back of the fuse box on your driver side foot well.
I have seen that go bad a number of times that the cluster lights give wrong indications.
Old 04-25-17, 12:06 AM
Deegee
Deegee's Avatar
Any pics of this relay behind the fuse box?
I had the same exact problem. I have a thread around here somewhere... I ended up replacing the door actuator and the problem still persisted. Im going to try searching for what Gerrb is describing next..
Old 04-25-17, 08:43 AM
gerrb
gerrb's Avatar
there is one huge white in color fuse / relay box / connector box (all wires you see on that area go there) on the driver side footwell .. it is held by two 10mm bolts . Behind that is the integration relay which is around 2"x3" .
Old 04-25-17, 02:07 PM
Sc400NL
Sc400NL's Avatar
but where is the door switch ? my dome light doesn't come on sometimes and i can't find the door switch
where is it located ?
Old 04-26-17, 06:41 AM
JuiceIam
JuiceIam's Avatar
Yea I have been looking for a door switch. It is either an integrated part of some other system or very well hidden.
Old 04-27-17, 04:08 AM
gerrb
gerrb's Avatar
The door switch is part of the door locking mechanism.
The way I test that is I open the door , get a screw driver , push that door latching mechanism to simulate door closing . That gauge light should go off . Then I just push the door latch mechanism back out. The system itself senses that through the detterent ECU . The 10amp dome fuse will provide power to the gauge door light that is connected to the integration relay if the system sees that a door is open. That is the reason the first suspect is usually the integration relay . That is the first component that gauge door light is connected aside from the power source coming from the 10amp dome fuse.
The following 3 users liked this post by gerrb:
Deegee (04-27-17), Returd (04-27-17), Sc400NL (04-30-17)
GCNTSi
RX - 1st Gen (1999-2003)
13
02-24-19 09:30 PM
jbdvm1988
GX - 1st Gen (2004-2009)
02-13-12 08:05 PM
Gville350
10-10-11 11:20 AM
ThomasGS4
08-29-11 07:20 AM
lexus4ever
Maintenance
03-11-03 12:28 PM
Quick Reply: Door is closed. But dash says otherwise
