Part differences between Candian and Japanese assembly?
Old 04-22-17, 09:37 AM
lexisaurus
lexisaurus's Avatar
Default Part differences between Candian and Japanese assembly?
I would think that there ought to be 0 differences but sometimes I do notice that there different part numbers depending on assembly location.
Does anyone have a list of differences?
Thanks!
Old 04-22-17, 12:13 PM
BlackLexRX
BlackLexRX's Avatar
It has to do with the suppliers between the 2 facilities. Mainly sensors and the like but there is really no rhyme or reason to it. Use mylparts to view diagrams and listings which will describe which parts fit which country of origin. Then you can take that correct part number and description to any parts store and buy the correct part for yours. I usually just order from mylparts then and there.
05RX330AWD (04-27-17)
Old 04-24-17, 04:03 AM
mandyfig
mandyfig's Avatar
Parts will be identical, has to be. That's the intent.
Old 04-24-17, 04:18 AM
RedGemini
RedGemini's Avatar
There are differences with some parts. Headlights are one. It's good to know what you're buying, especially if you buy the wrong $1,600 headlight. It wouldn't be a good day. O2 and A/F sensors are also different.
If your VIN starts with 2T2, it's Canadian.
Old 04-24-17, 04:33 AM
smassey321
smassey321's Avatar
Rear headrests are different. And thus hatch covers are different because the headrest shafts that the cover clips to are not the same size.
Old 04-25-17, 10:10 AM
mandyfig
mandyfig's Avatar
I am a bit confused about the differences between Japan and US made RX. If they are sold in the US, then they have to be identical.
Old 04-25-17, 10:22 AM
BlackLexRX
BlackLexRX's Avatar
They are same spec but have different part numbers and can be different slightly. Read my second post as to how to order correct part number.
Old 04-25-17, 10:29 AM
mandyfig
mandyfig's Avatar
You are right, you have to specify the VIN number when buying. For you to get the correct version.
Old 04-27-17, 03:45 AM
05RX330AWD
05RX330AWD's Avatar
Excellent reference point for parts, also for aftermarket parts as cross references, decent prices, although mylparts does not ship to Canada.
OldLs400
12-15-22 02:19 PM
deputy865
05-25-16 07:50 AM
ravengotu
RX - 1st Gen (1999-2003)
07-10-08 04:42 AM
Quick Reply: Part differences between Candian and Japanese assembly?
