Cut out (or exhaust valves) on stock exhaust
Hello everyone! I am writing from France and I will very soon be the owner of a lexus isf in replacement of my ma honda s2000. The first thing I plan to improve is the sound of the exhaust.
Have some of you already installed exhaust valves on an original exhaust? Something like this video :
My idea of fitting the exhaust valves
New mod: I wanted a more beautiful exhaust soud without spending too much money in a complete exhaust system. I bought a QTP qtec33 cutout in the USA that I have welded on my stock exhaust. I activate the opening and closing with a switch. I'm very satisfied with the soud.
I am seriously considering this as well. After going through all the trouble of having a 3 inch exhaust on my last vehicle with the turbo, and then spending more time and money afterwards trying to figure out a way to quiet it down, this seems like the perfect solution. Cheap, and a full 3 inch exhaust at the push of a switch. Only issue back then was the quality wasn't the best, but maybe they have their kinks worked out.
I have to disagree with a few points there.
1. There is enough airflow to move the gasses out pretty quickly under the car. I've never seen issues of undercoating catching fire. it's not exactly aimed up at the undercoating either.
2. The cutout would be behind the transmission where it's at so heating the transmission wouldn't be an issue.
WYKP?
1. The vehicle will certainly fail inspection (in NY) if the inspector sees it and understands what it is - a release of toxic gas into the cabin. Rebuttal (if true): it's fail-safe, and is only open (and dangerous) when voltage is applied.
2. What do you think releasing hot exhaust on to the transmission or differential case does to the fluid temperature? Sustained use will set fire to undercoating, rubber donuts, etc.
3. I agree, that "Y" looks restrictive.
Route it back to after the bumper or you'll be breathing it.
Not saying this is the perfect solution, rather just another option.
WYKP?
Ok sure, I'm confused how is an inspector going to see this exhaust cutout if they're not looking under the vehicle? or are you worried that they'll see the switch? Also still not seeing how this would be consider releasing "toxic" gases into the cabin.
This cut outs do not all have a spring that allows a fail safe. The motor opens the plate and then the motor reverses to close the plate. It's possible for it to fail close or fail open if the motor fails.
ultimase (08-06-17)
