LED Turn Signals - Relay
Old 04-15-17, 10:25 AM
TRISTAN3
TRISTAN3's Avatar
Default LED Turn Signals - Relay
Hey everybody,
I want to switch my signals to LED (Front and Back) but because my car is still under warranty, I don't want to wire in resistors. Has anyone found or used a LED relay???
I know IJDMTOY has them for the second gen IS but I'm having trouble finding it for the 3IS.
(2014 Lexus IS250 F-SPORT)
Old 04-15-17, 01:02 PM
Lveyolfe
Lveyolfe's Avatar
I got the 7440 error free LED turn signal from ijdmtoy for the front and back. They come with that bypass crap so you don't need to worry about nothing, works great too
Old 04-15-17, 02:48 PM
SilvrBulet
SilvrBulet's Avatar
Are there any comparison pics? OEM vs LED replacement turn signals?
Old 04-15-17, 02:59 PM
dchar
dchar's Avatar
I am currently using these for my front turn signals in my GS. They work great and no additional Resistor or Decoder box needed; just plug it in. This is ideal so when you service your car at the dealer, they wouldn't know you're using them.
https://store.ijdmtoy.com/No-Hyper-F...s-p/20-085.htm
Old 04-15-17, 06:29 PM
Lveyolfe
Lveyolfe's Avatar
YouTube 2014 IS250 led turn signal ijdmtoy. They do a comparison video
Old 04-16-17, 06:17 PM
Makool
Makool's Avatar
So just to be clear these LED bulbs will work on IS 250 2015 Canadian Version? Single HID headlights? Can you shed some light, I'm interested on these if they could work on my IS.
As always, thank you!!
Old 04-17-17, 07:38 AM
Lveyolfe
Lveyolfe's Avatar
Im not sure if it'll work on Canadian cars, probably will. You could just email ijdmtoy and ask them. They usually respond within a day or two
Old 04-17-17, 01:40 PM
Makool
Makool's Avatar
Yes, I did try but never hear from them, I'll try to call and find out, thanks!!
Old 04-18-17, 02:12 PM
E46CT
E46CT's Avatar
Received 2,079 Likes on 1,570 Posts
check out the video in my sig. note NOT ALL LEDs are created equal. most are dim and suck. you have take note of WHICH LEDs you are installing and their overall design. Don't forget the housing you are installing them in is designed for bulbs that emit light in ALL directions. some LEDs are not only weak, they emit light uni-directionally. So you'll get REALLY poor output which can be dangerous.
Old 04-20-17, 06:00 PM
Makool
Makool's Avatar
Thanks for the info!!
Old 04-24-19, 01:51 PM
aymanzaher
aymanzaher's Avatar
Default Led Turn Signal Lexus GS350 2013 Relay FLASHER
But but if you installed 2 pairs one in the front and one in the back it doesn’t hyperflash? Also I’ve heard about led flasher relay, but I don't exactly where is located, maybe in the cluster panel? It easy to install some led flasher relay or its not recommended? Thanks
Old 04-24-19, 11:49 PM
Flash5
Flash5's Avatar
I'm pretty sure this car doesn't have a relay. Older cars from what I remember are the ones that used relays.
Old 04-25-19, 02:41 AM
ex00
ex00's Avatar
You can find the same bulbs on aliexpress for half the price with the same functions(ordered and tested for over a month and works really well, super bright as well). I think the relay from what I have read was that it's integrated into the gauge cluster.
Old 04-25-19, 04:38 AM
Sasnuke
Sasnuke's Avatar
Received 1,732 Likes on 1,368 Posts
The relay is integrated, so it's not a physical relay you can unplug and plug an LED one in. The resistors are the way to go.
Old 04-25-19, 06:04 AM
Napalvr
Napalvr's Avatar
Anyone try these? 50W 6 ohm 9-14VDC 16 gauge.
Quick Reply: LED Turn Signals - Relay
