New to me thread for recent owners
Based on another post, I am starting this thread and hope the new owners can share their experience and questions here. Existing owners can post the replies and I hope they will chose to ignore the questions and not respond with ... "go read the owner's manual" ... as it is understood. This thread may has the tendency to go all over the place. I hope the mods will give it some latitude.
Rattle box
I am going over, new to me 2011 450H, and found 3 rattle boxes in the tail end. One each behind the rear wheel and 1 in the middle. They are plastic shells with drain holes in them but I found sone pebbles which I had to shake out .
Previous owner, never removed the sticker from the passenger side rear side window, and it had dried out there. I had to resort to a blade to scrape it off.
Salim
Rattle box
Salim
Let me correct myself ... the rattle sound was not heard by me seated in the driver seat.
The false panelling [esthetic or aerodynamic] seems like a collection box. For me the rocks/pebbles came out without removing the panelling, but I had to beat them out.
Salim
Salim
cockpit lighting issue
Did my first night time drive.
Set of buttons above the rear view are not lit up for me. Is there an back light in them?
SOS button lights up read and a fine green light is lit up near the mid trailing edge but all other buttons are dark [home link, light switches, moon-roof switches]
Salim
Salim
Salim
Salim
2010 RX450h... mine don't light up either, and I've had the same trouble in the dark with Map Light versus Homelink buttons.
Might be a bit cheesy, but there is always this option >>> (You could always cut one down and use just a very small piece on each button.)
OR... just use a small drop of this >>>
OR... just a tad of this powder in a small drop of superglue on the button surface >>>
Randy
Night time visibility of the top control pod is a miss for Lexus. Even when you turn the light on [any three] the beam of light travels downwards and does not light up the buttons.
Brightly lit pod would be an eye sore and distracting, but faint light would have been good.
Any one knows what is the purpose of the light green light in the middle trailing edge of the pod?
Salim
Salim
I will try to post a picture ... picture worth thousand words I guess.
New owners, please make sure you clean the lap belts with mild soap and water. Just did that last night.
Salim
There is middle (yellow brown light --courtesy light) and then two map lights (LEDs) but one faint green light ... smaller than the auto green light on the rear view mirror.
Salim
Salim
Enform login issue
Tried to setup an account and the site did not recognize my vin
Any one else had problem/success with 2011 450h?
Salim
Salim
12 Speaker Premium Sound- Subwoofer question
Hello, new owner of a 2014 RX350 for my wife. Since this thread is open for us newbs, I'll ask here! I've researched all over online and here on the forum but can't seem to find any specs on the factory sub (non ML). I believe it is 200mm or (round up to) 8", dual voice coil, but don't know what the ohm rating is, has anybody confirmed this? If the cover popped off, I'd just take it out and throw a meter on the terminals, but I understand it's not that easy to get to. Thanks in advance, appreciated.
Salim
Dug in there yesterday, it's actually single voice coil, and 2.5 ohms according to my digital multimeter in case anybody else wants to know.....
