Suspension Springs, shocks, coilovers, sways, braces, etc.
For those on bags
Old 04-02-17, 11:16 PM
NebulaGrey
NebulaGrey's Avatar
Default For those on bags
gonna be installing my air bags soon. Went with airlift 3h and d2 bags/shocks. For those who are already on air - any tips can u give? Running lines, installing height sensors, etc. thanks in advance.
Old 04-03-17, 09:27 PM
maveriCK..
maveriCK..'s Avatar
i used all existing oem holes to route my lines..and i ran them along the sideskirts.
i also used split wire loom tubing for extra protection for the air lines..
there are two rubber grommets where the spare sits you can run the drain/fill valve line and filter drain line
i only have the 3p so no height sensors.
for the ignition wire..i ran it towards the drivers side then under the dash there's a 10a fuse i believe labeled "lh-ig" and used the provided "add-a-circuit fuse" adapter to tap into (you can use the inline fuse instead if you want)
the hardest part is setting up the trunk the way you want it...mine is just a basic setup.
everything is easy just like installing coilovers..follow the instructions and you cant go wrong.
i used this guide for removing the suspension https://www.clublexus.com/forums/sus...all-guide.html
no one helped me with mine so hopefully this helps you a little with yours..
any questions just pm me.
Old 04-04-17, 07:38 PM
NebulaGrey
NebulaGrey's Avatar
Cool thanks for the tips. So you ran the airlines outside, I was thinking of running it inside along the sides. You got a nice setup there - I use my trunk often so I was thinking of using the spare tire compartment to house everything.
What bags are you using and did you run into any rubbing issues?
Old 04-04-17, 10:44 PM
maveriCK..
maveriCK..'s Avatar
you can run the lines inside too..i chose outside because it was easier.
i am using airforce bags. as long as you position the bags right they shouldnt rub.
the guide should have directions on how to position the rear bags.
Old 04-05-17, 12:48 PM
mizz900
mizz900's Avatar
looks nasty!
Old 04-11-17, 02:02 PM
NebulaGrey
NebulaGrey's Avatar
Installed.... just need fine tuning. Ran the front airlines through the cabin along the side. Ran the power line along the passenger side - tapped the "avs" fuse under the glove box for ignition.
maveriCK.. (04-13-17)
Old 04-13-17, 03:06 PM
NebulaGrey
NebulaGrey's Avatar
Plane Jane trunk setup. It gets the job done. Lol
Old 04-13-17, 03:42 PM
mrpartsman
mrpartsman's Avatar
Nice set up, what size wheels and offset r u running and did u have to take the inner fender covers off.
Old 04-13-17, 03:48 PM
NebulaGrey
NebulaGrey's Avatar
thanks. Wheels are 19x8.5 and 19x10. I forgot the offsets - I think 35/38. 245/275 front and rear tires. Didn't remove any fender liners. However the Front wheels are pushing on the fender liner tabs when air'd down.
Old 04-17-17, 07:43 PM
DaPope10
DaPope10's Avatar
maveriCK.. & Nebula,
Can you both PM me what you paid for your setups (or just reply here if you don't mind it being in the open)? I want to do bags so bad but can't figure out what a reasonable price would be. It ranges so much and there is so much information out there.
Any help would be appreciated. Thanks.
Old 04-17-17, 08:06 PM
NebulaGrey
NebulaGrey's Avatar
just about 3300 I paid. 1500 for 3h system and 1800 for d2 air suspension.installed myself so no charge there.
Old 04-17-17, 08:16 PM
DaPope10
DaPope10's Avatar
I will look into those. Did you buy it from a particular shop? Or just pieced it together?
Old 04-17-17, 08:19 PM
NebulaGrey
NebulaGrey's Avatar
I bought the airlift from local store and suspension from a vendor on here. U can hit up the vendors here for prices and check out bagriders.com.
Old 04-17-17, 09:47 PM
kamskeez
kamskeez's Avatar
Looks amazing aired out. Nice work on the install!
Old 04-19-17, 04:24 AM
Juju00
Juju00's Avatar
Dapope10,
I didn't do install so I couldn't chime in but I paid 1525 for airlift 3p 4gal tank
2325 for airforce struts
Paid​​​​​​ for install 1060.
Quick Reply: For those on bags
