Correct Wheel Lock Key Replacement for '08 ES 350?
Old 03-30-17, 01:02 PM
LitGrandPa
LitGrandPa's Avatar
Question Correct Wheel Lock Key Replacement for '08 ES 350?
It's time I changed/rotated 2 of my tires, but I can't since I'm missing the original wheel lock key. Does any have a link to a replacement one with the right specs I can purchase,? Thanks in advance!!
Old 03-30-17, 01:07 PM
Clutchless
Clutchless's Avatar
Received 1,091 Likes on 931 Posts
You need to review all the docs with the purchase materials and owners manual as there should be materials from MacGuard or whatever lock company it is with your lock key code so you can order a new one. In the alternative, a Lexus dealer should be able to look it up for you by your VIN as they should have registered it at time of sale. Good Luck!
I lost one once on a Mazda and ordered a replacement using the code document I found stashed with the owner's manual.
LitGrandPa (03-30-17)
Old 03-30-17, 01:18 PM
LitGrandPa
LitGrandPa's Avatar
Okay awesome I'll try to find it in the owner's manual. If not, I'll call a local Lexus dealer. Thanks!
Old 03-30-17, 07:34 PM
KMiles
KMiles's Avatar
I have a Toyota dealer about two miles from my home. I took my Lexus there and the wheel lock set they had there was an exact match for our 2010 Lexus ES350. I'm sure it cost a little less there than at the Lexus dealer, but that's just my guess.
LitGrandPa (03-31-17)
Old 03-31-17, 02:43 PM
PoorES
PoorES's Avatar
Wheel locks won't really stop thieves. They only stop you from removing your wheels when you get a flat. Go to your local Toyota dealership and get them removed and replaced with normal lugnuts.
If you really want to get lugnuts, then you can also order them from Amazon. Just search for Mcguard.
rsutoratos
RX - 3rd Gen (2010-2015)
04-07-14 11:30 AM
soda7o
11-03-11 01:17 PM
mandyfig
10-05-11 08:22 AM
JerryWB
08-04-10 07:06 AM
Curry
03-26-10 10:51 AM
Quick Reply: Correct Wheel Lock Key Replacement for '08 ES 350?
