sc430 how to replace instrument cluster light bulbs with led
Old 01-27-17, 07:41 AM
foreste1
foreste1's Avatar
Default sc430 how to replace instrument cluster light bulbs with led
Can somebody give me step by step directions please to pull instrument cluster I want to install new led bulbs, the old ones are just too dim even at full brightness. I read some old threads but dont see step by step and some say remove steering wheel and other say no you do not need to remove steering wheel, which I do not want to remove it.
Old 01-31-17, 02:02 AM
sexusc430
sexusc430's Avatar
You do not need to take off the steering wheel, and unfortunately they are welded on, I've wanted to change it but don't want to attempt it lol
foreste1 (01-31-17)
Old 01-31-17, 06:38 AM
Jabberwock
Jabberwock's Avatar
The cluster on a 2004 is pretty easy to remove. Move the steering wheel all the way out and down for ease of access. The surround trim assembly (big plastic trim piece surrounding the cluster dials) is held on by 4 tabs. Pull gently but firmly straight back and out on the surround trim assembly. It should pop out with just firm pressure. Once the cluster trim surround is removed there are four screws that attach the cluster to the dash. Remove the four screws and then the cluster will come loose. Gently remove one cable connection from behind the cluster and the cluster can them be removed.
Lights in the 2004 cluster are soldered in led surface mount lights. There are a few places (web search instrument or gauge cluster repair) that you can send the cluster to get lights replaced or different color lights but not sure they could be any brighter.
foreste1 (01-31-17)
Old 01-31-17, 09:32 AM
foreste1
foreste1's Avatar
Ok thank you very much! I was hoping I could just order new bulbs and switch them out but if I need to send some where probably will stay with my boring cluster lights!!
Old 02-02-17, 03:30 PM
TaninAuto
Sponsor
TaninAuto's Avatar
Hi, Tanin Auto Electronix here. We are vendors on the site that specialize in instrument cluster repair as well as selling DIY parts for customer repairs. We have LEDs available and you can confirm the ones that you need and check on our site for part match but look at this link for the BA9S Reverse Polarity Lexus SC430, Mercedes, BMW, Audi LED:
http://www.taninautoelectronix.com/B...9s_reverse.htm
This LED is reverse polarity. Positive voltage is on the outer shell, negative is at the bottom point. For many European vehicles and also Lexus SC430.
Replacement for the following bulb part numbers:
1445, 17053, 1815, 1816, 182, 1889, 1891, 1892, 1893, 1895, 1895A, 216, 293, 363, 3886X, 3893, 53, 53X, 57, 6253, 64111, 64113, 64115, 756, 1896, 51
Feel free to give us a call tomorrow, 9-5pm CST and speak with one of our sales team with any questions on parts. We hope we can help you out and save you some money and hassle on this repair.
Thanks,
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
Old 02-03-17, 10:44 AM
ShawnOk
ShawnOk's Avatar
Thanks,
I don't think the bulbs which you have referenced have any relation to the instrument cluster. The link you've provided would suffice for the overhead map lights in the SC430, as they have reverse polarity. I believe the only way to change the LEDs on the instrument cluster, as indicated in the previous posts above, would be to unsolder the current LEDs and resolder new, brighter LEDs. Do you offer this service at TaninAuto?
Old 02-06-17, 10:11 AM
TaninAuto
Sponsor
TaninAuto's Avatar
Unfortunately, we do not offer that service here presently. Hopefully in the future we will for our Club Lexus customers! Sorry the bulbs posted above won't work for what you are looking for. The bulb numbers are in the post just incase they can help anyone out with future LED replacement needs for the SC430.
__________________
262-456-4147
Old 07-17-17, 07:14 PM
TaninAuto
Sponsor
TaninAuto's Avatar
We now offer this service for the SC430
http://www.taninautoelectronix.com/R...430_repair.htm
We also have complete clusters for sale:
http://www.taninautoelectronix.com/2...30_cluster.htm
__________________
262-456-4147
Old 07-17-17, 08:10 PM
ShawnOk
ShawnOk's Avatar
Hello again, so with this service in your newest post; it is to only repair damaged LED's, correct? Have you found a way to increase the brightness of the OEM LEDs? or replace the OEM LED's with increased "wattage" LED's? Across the years, I believe the 2010 had the special instrument cluster that was MUCH brighter than the older 2001-2009, but I can't recall the name of the feature (maybe someone can chime in). Anyway Tanin, have you find a way to increase brightness?
Other members have done it, as well as the entire radio and A/C unit. Changed to white LED. Not sure how but here's one example. If you are able to do it, I would be VERY interested in all (radio, cluster, and A/C unit). https://www.clublexus.com/forums/sc4...-of-sc430.html
Old 07-18-17, 06:19 AM
TaninAuto
Sponsor
TaninAuto's Avatar
The picture in our link is about 3 times brighter than what we started with. If your cluster looks like the picture then we can't make it brighter. If it looks like every other 10-15 year old SC430 cluster we have seen, then we can.
We don't specialize in radios, only clusters and climates. We haven't seen a radio or climate for this model so we can't say what is feasible and for what $ amount, but if it can be done then we can do it.
__________________
262-456-4147
Old 07-18-17, 09:28 AM
ShawnOk
ShawnOk's Avatar
Great to hear! Just as a side note, where are you located?
Old 07-18-17, 09:44 PM
texsexlex
texsexlex's Avatar
...under their name it's listed as Wisconsin, so maybe they are located there.....lol...typing this, I thought this sounds like I'm being funny, but I really wasn't....lol
Old 07-18-17, 10:14 PM
ShawnOk
ShawnOk's Avatar
Haha thanks TexSexLex. I was using the mobile version on my tablet and it doesn't show as much info on the forum. Thanks though!
Old 07-19-17, 07:34 AM
TaninAuto
Sponsor
TaninAuto's Avatar
We are located just outside of Milwaukee, WI . Our address is:
Tanin Auto
7012 HWY 31, STE 100
Racine, WI 53402
__________________
262-456-4147
Old 07-19-17, 07:54 AM
mrblister
mrblister's Avatar
Tanin Auto
Racine, WI 53402
If I were to pull my gauge cluster is the car still drivable with it out ? Are there any risks of getting error codes or any other problems
ivanj (04-20-19)
Quick Reply: sc430 how to replace instrument cluster light bulbs with led
