Multimedia System Update (25OCT) Version V15A8910
Old 10-28-16, 11:39 PM
wilhem316
wilhem316's Avatar
Default Multimedia System Update (25OCT) Version V15A8910
Just want it to share the latest. Couple of days ago my system rebooted by itself while I was driving for the first time. I will update my system later today.
UPDATE TYPE - OPERATING SYSTEM
Your Lexus Vehicle has an available multimedia software update (Version V15A8910).
This update is designed to improve the performance of your multimedia system. Updates include the following:
-Voice Recognition is Inoperative
-Reset while making a turn off of the highlighted route
-Navigation system reboots intermittently
There may also be other enhancements included in the update. Click on the DOWNLOAD button to download the software.
The following 2 users liked this post by wilhem316:
ba2sy (06-29-17), RCFormante (06-28-17)
Old 06-28-17, 06:40 PM
RCFormante
Supercharged!
RCFormante's Avatar
Just updated, just figured out that I can double tap on the touchpad instead of pressing down!
Ninja10r (07-05-17)
Old 06-30-17, 11:49 AM
GetKinetic
GetKinetic's Avatar
Is there a way to "check for pdates" in the system interfsce? Or do I have wait for the car to tell me it found it?
Old 06-30-17, 11:57 AM
RCFormante
Supercharged!
RCFormante's Avatar
You can check it here:
https://securedp.lexus.com/download-app/downloads
Old 06-30-17, 03:28 PM
ChuH
ChuH's Avatar
Great! Just updated mine.
Old 07-04-17, 03:38 PM
wilhem316
wilhem316's Avatar
Punisher, follow the instruction with the exception of step 7 just click on update history. That should help.
1. Download Update Software
1)Download the software update file to your USB memory drive.2)Bring your USB memory drive to your vehicle and proceed with the remaining steps in these instructions to update your multimedia system.
2. Software Update
1)For this and all following steps, keep your vehicle parked in a well-ventilated open area outside, suitable for running the engine, not in an enclosed structure such as a garage.Note: The entire process may take up to 15 minutes. Example screens are shown in these instructions. Actual screens may vary by model.2)Start the engine ("READY" light on on hybrid models)a)The LEXUS emblem will be displayed on the navigation screen first.b)Then wait for the display to switch to the "CAUTION" screen, and then select Continue. The map screen will display.3)Insert the USB Flash Drive into the vehicle USB port. Refer to your Owner's Manual for the location inside your vehicle.Note: Be careful not to close any doors/lids near the USB port to prevent damage.4)Press SETUPa)Press the SETUP button (models without Remote Touch controller).b)For models with a Remote Touch controller, first press the MENU button, then select Setup from the navigation menu.5)Select General.6)Select Software Update (may need to scroll up or down).7)Select Update.8) Select Update Software on the Software Update screen.
Note: This selection will be "grayed out" if the software on the USB flash drive is the same as or older version than what's already on the Multimedia system. If this happens, there is no need to update the Multimedia system.9)Select Yes10)Wait for the software to install.11)When "The software is ready to update." displays, shut off the engine (shut off hybrid system on hybrid models). Then, start the engine again ("READY' light on on hybrid models).a)DO NOT shut off the engine or hybrid system again until step 13, AFTER THE MAP APPEARS ON THE NAVIGATION SCREEN.b)DO NOT Remove the USB memory drive from the vehicle USB port. The "CAUTION' screen may appear on the multimedia system for several minutes during this final portion of the update.12)Once the navigation screen is present, the update is complete.13)Remove the USB memory drive and shut off the engine (shut off hybrid system on hybrid models).
Kramer (07-07-17), skipetenj (07-04-17)
Old 07-04-17, 04:29 PM
danielTRLK
danielTRLK's Avatar
how does one update the map software? I got a 2017 map microSD but it sort of just freezes for a long time.
Old 07-05-17, 06:44 AM
GetKinetic
GetKinetic's Avatar
Thank you Wilhem!!!
Old 07-11-17, 05:18 PM
JB5674
JB5674's Avatar
I tried to do this and it didnt work. I am sue for service soon, so I will just have them do it at the dealer
Thanks for the heads up!
~JB
Old 07-20-17, 07:12 AM
Ne1tHeRe
Ne1tHeRe's Avatar
Mine just rebooted on it's own when on the way home from my 15k service. I guess I have the update. Will have to check the version.
Old 07-23-17, 09:31 AM
wilhem316
wilhem316's Avatar
JB, must of the time the issue is with the formatting and/or the flash drive. I had some issues the first time and had to reset the complete system.
Old 12-27-19, 09:27 PM
OmarX911
OmarX911's Avatar
where is the link to download it !!
Old 12-28-19, 06:15 AM
Ne1tHeRe
Ne1tHeRe's Avatar
Originally Posted by RCFormante
^^^^This link?
Old 12-28-19, 05:06 PM
OmarX911
OmarX911's Avatar
I cant download anything
Currently no updates available for this multimedia system.
Old 12-29-19, 10:48 AM
e2dag
e2dag's Avatar
I have all of the documents and firmware file for the Nav update. This update only applies to 2015 and 2016 years. PM me and I can send a link for the files.
OmarX911 (12-29-19)
Quick Reply: Multimedia System Update (25OCT) Version V15A8910
