IS250 carbon buildup - What works? What doesn't?
I have read about the carbon build up problem in is250, why it happens, and how it affects the car. I have come across a few solutions to the problem but I am now sure what works and what doesn't. If you have tried something to avoid/fix the problem, I would love to hear about your experience.
Apart from the engine rebuilding from Lexus, I have come across two types of solution -
1. Slow down carbon build up.
This can be done by installing a catch can which blocks the oil vapors and carbon going from crankcase to intake valves. Theoretically it sounds a good solution but does it work in real.
Another way to slow down carbon build up is drive hard regularly. When you drive easy, more air from crankcase is sent to intake which means more carbon buildup.
2. Clean up the carbon occasionally.
I have come across quite a few options for this and not sure which is the best or easy DIY or cheapest. Some of the options are -
What solutions have you tried? What's your experience with the solutions you have tried?
- Lexus service top-engine cleaning. (How often do you have to do this?)
- Put seafoam in in throttle? (not sure how exactly this is done). Valvoline has a service similar to this -
- Open the engine intake manifold, close the intake valve, and apply some cleaning agent to the valve. Cleaning agent can be either chemical or physical (walnut blast). After cleaning, vaccuum out the cleaning agent. (How much does this cost?)
- Italian cleanup. Drive the car at high rev for sometime (10-20 min).
Here are my thoughts on the carbon issue that the IS250's have. It seems that Direct Injection and the PCV System are the two major sources of carbon build up.
I have watched enough videos and used the product myself to feel confident that SEAFOAM works the best. You need to buy the can with the straw that slips into the throttle body/intake after the MAF. I would recommend doing this treatment at least every 3000 miles. Chrisfix on youtube has a video you can find here:
Does Seafoam Actually Work in a Car? (with Proof) - YouTube
You could also very carefully pour SEAFOAM (regular can) very slowly into the vacuum line from the PCV to the engine. Use caution and just pour about a 1/3 of the can in (very slowly). Use the other 2/3 of the can just before your next oil change. All you have to do is pour it into your engine (through the oil filler) and let it run for about 15 minutes. Then drain and fill with fresh oil.
Here is something I have been thinking about and I think it may significantly reduce the carbon build up. I'm open to any suggestions if you see a problem here.
First thing I would do is plug the vacuum line that runs to the PCV Valve. I would then take out the PCV Valve and insert a fitting or adapter that looks like this:
http://pressureconnections.com/produ...ARBS/4501.aspx
I would make sure that it has the correct threads and that it is a 3/8" hose barb. After substituting this for the PVC Valve I would run a 3/8 hose along the firewall and down to the side of the Master cylinder and make sure that it mounts somewhere below. The last thing I would do is put a G12 Fram Fuel filter on the end of the hose that runs from the 90 Degree barbed hose fitting that replaced the PCV Valve.
I believe this would provide adequate crankcase ventilation and would not affect the vacuum of the vehicle.
You would avoid sucking all that nasty oil and vapor back into your intake and top end of your engine that is causing carbon buildup. A catch can will help but why not just eliminate the problem entirely by venting the crankcase like all vehicles use to and some still do.
WylerLexus (06-22-17)
IS250 will alway have carbon buildup because of direct fuel injectors. Didn't want to deal with the issue in the future so we trade it in for another Lex now own IS350/ES350
These cars have good trannies though right?
thanks,
Mitch
is350 doesn't have direct fuel injectors?
Carbon build up is due to poor quality fuels, poor filtration of EGRed fuel residuals and poor ring and valve guide film seal in the engine. Keeping them down is very easy and simple. However, once a deposit forms, good luck, they just continue to grow. Unless you use Ethanol or cleaning agents.
Using a quality oil + filter + fuel, and you would never have any of these deposit issues. Occasionally I use VP's fuel system cleaner to keep things clean, but merely as an insurance and more of my desire to try and nail the perfect combo. You can try running E20 for a small amount of time and then go back to E15, this will help to reduce some deposits formed.
Catch cans will reduce the EGRed residuals but it's just that, reducing. Those deposits can't be treated physically because they are polar. If you have a fuel and an oil that can achieve solvency post combustion together than you will have no issues.
This is an argument that gets sparked in lots of other threads with guys saying, we've never heard of these issues! Yeah, until the car gets to this age, then the negligence starts to show.
pedrocelso (08-30-22)
