08' ES350 Moonroof / Sunroof Rattle
I have searched and searched but cannot find a solution. I just inherited a 2008 ES350 with 52k on it and the sunroof rattles only when open from bhind the drivers side head area. When driving, I can get it to stop if I push up or pull down on it a little bit, but like I said...it only happens when in the full open position. Has anyone encountered this? Any fixes? Thank you for any informaiton.
Craig
Craig
Having the same problem Craig.
Found a post on 4th gen ES350 maybe you can locate it and see if the issue is solved there.
https://www.clublexus.com/forums/gs-...e-culprit.html
Speaking of the panoramic roof, Yes, i have it too. On mine, it is the wind deflector, i've tested it by holding the deflector while on bumps and yes, it does stop it. The spring arms seems to be weaken over time.
S54toIS350
03-19-15 11:21 PM
