Tow Wiring? Non Tow Package Model
So I went under the car just to see if there was any pre wiring in non-tow package models, mine is a F-sport / No tow package.
I found this plug inside the rear bumper on the left... is this the tow lights pre wiring?
If I got a hitch would I just plug the lights on the trailer into this?
Ah you are right I think... so it seems the pre wiring is there even in the non-tow package equipped models which makes me happy.
It looks like it fits this.
https://www.etrailer.com/Custom-Fit-...id=20161174043
You have the wire, but likely no power. There is a converter box inside under the passenger side luggage compartment trim that is likely missing. You also do not have a transmission and engine oil cooler. I would not tow without a transmission cooler.
Non tow packge RX's were rated for 2000 lbs., 3500 with.
Makakio (07-20-23)
How would i tell if there is power? What would i be looking for in the compartment?
Or just check with your dealer, might be safer and easier.
You should have a tow fuse if it is wired. Check the manual for the position of that fuse and check to see if there is a fuse there. You should also be able to check the voltage with a volt meter. With your lights on you should be able to read 12v across at least two of the wires.
Perhaps Lexus should advertise that the rx350 is not able to carry a bike on a bike rack that fit into the receiver.
Yup I agree, and I dont understand why the old accords were able to tow at least 1000 to 2000 lbs and this cant tow anything at all?
I plan on towing max 1000 lbs, ill probably add an aftermarket trans cooler just to be safe, although my friend who worked at toyota/lexus for awhile said there is a integrated trans cooler already under the radiator. When I looked I did see some lines going to the bottom of the radiator that said AT-OIL... so sounds like there may be something already... although not as robust as the one that comes with the tow kit.
Perhaps but the new owner will have to wire the vehicle for lights in order to tow legally. I imagine that, to wire it correctly, would require a bit of expertise.
