CL Vendor Products for IS-F New product details, group buys and more, specifically for the IS-F model from CL Vendors
New Product Combo 2P rotor kits (Front and Rear) packages and 15/14" 2P floating BBK packages.
Old 09-04-15, 09:12 AM
FIGS
The Maker
FIGS's Avatar
Default Combo 2P rotor kits (Front and Rear) packages and 15/14" 2P floating BBK packages.
As seen on MOTOIQ.com
and used in WTAC competition
Hi guys, our 2P rotors made by RB have been a huge upgrade for track IS-F's and we have recently been able to reduce the combo price by 10%. For those unfamiliar, there are several key features of these patented technology rotors:
Design:
The cooling vanes are of a convergent nozzle design, which increases airflow and turbulence and makes discs cooler. (Illustration #1)
This is a big one, The center-mount flanges for hat mounting to the rotor ring have several benefits. (Illustration #2)
It allows the ring to be used on either side of the vehicle simply by mounting the hat on either side of the ring (unidirectional).
The stress load transferred from the ring to the hat is balanced.
Air inlets are widely open to both inboard and outboard sides of the rotor. More air suctions and even temperature on both sides of the disc surface.
Heat transfer from the disc surfaces to the hat is even and minimized by increasing the flange length and the airflow around the flanges.
Mounting flanges are on both friction surfaces ultimately provides
Front Rotor
355x32mm
Weight Comparison (per rotor)
One-piece 27.5 lbs.
Two-piece 20.5 lbs.
Weight Savings: 7.0 lbs.
Rear Rotor
340x28
One-piece 22.0 lbs.
Two-piece 17.5 lbs.
Weight Savings: 4.5 lbs.
http://www.shopfigs.com/v3/2psrtr-ISF-PKGLX-IRK-01
We also want to formally introduce our 15" front 6 pot 14" rear 4 pot forged caliper kit.
http://www.shopfigs.com/v3/BBK-RB-15...-2P-2302-2140k
These kits utilize the latest patented technology from RB Performance Brakes to deliver a light, versatile and affordable braking upgrade while also keeping long-term replacement costs affordable. 19" monoblock or 20" 3-P wheels required. See templates on the website.
Kit contains
  • 4 Two-piece center-mount open slot rotors
  • 2 6-Piston aluminum calipers front
  • 2 4-Piston aluminum calipers rear
  • 4 Aluminum adapters made of 7075-T6 Alloy (stronger and stiffer than 6061-T6)
  • 2 Sets (2 Pair) of stainless steel brake lines
  • 2 Sets of RB XT910 performance street brake pads Front and Rear
  • 1 Liters dot 4 brake fluid (Motul RBF)
Specifications
Rotors
  • Front 380mmx32mm
  • Rear 360mmx28mm
  • 2-Piece fully floating center-mounted rotors allow free rotor thermal expansion
  • Rotors are a special alloy iron material that is heat-treated for uniform micro grain structure. This process and material are the key to the highest level of braking performance and wear characteristics.
  • Aluminum center hats and rotor surface are EDP coated for protection. EDP provides better protection than zinc, especially on internal face coverage, like the internal vanes. EDP is also more uniform and will not separate under high temps.
  • Rear Hats feature a exclusive bi-metal cast iron sleeve for parking brake retention.
  • Convergent vane design
  • Patent Pending Open-Slot design combines slotted and vented rotor properties without the crack prone stresses involved with these 2 processes.
  • DACRO coated 10.9 fasteners on rotor ring to hat interface held in tension to allow floating under expansion loads
  • Caliper
  • 6-POT front and 4-POT rear Forged 6061-T6 weighing only 5.5/4.5lbs
  • Direct Bolt-on fitment
  • 7075-T6 Mount brackets are CNC machined and EDP coated
  • Low profile design for more wheel fitment options. Clears factory 17" wheels on IS300.
  • 38mm internal seal piston is thermally vented to reduce heat transfer 90% over Aluminum pistons commonly used in BBK calipers. This means longer times at the track and less heat conduction into the brake fluid.*
  • Powdercoated finish in red, black and hard anodize options. FIGS Orange also available special order.
  • Uses Standard FMSI pads (D1371 and D1383 ) making replacement pad options vast.
  • Tethered EPDM bleeder cap means no more lost bleeder caps.
  • Made in the USA , Designed fully assembled and 100% hydro tested prior to shipment in Fullerton,CA. Canada shipments are tax exempt due to NAFTA guidelines.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 01-28-16, 06:04 PM
FIGS
The Maker
FIGS's Avatar
Hi guys contact us for special pricing right now on the package with pads.
__________________
Old 05-31-16, 08:33 PM
5280ISF
5280ISF's Avatar
Mike,
Are the front and rear rotors both drilled and slotted? You run these on your track car, correct?
Do you sell a four piston caliper set for the rear only? I did not see this on your site...
Thanks.
Old 06-02-16, 04:27 AM
PDP180180
PDP180180's Avatar
PM'd.
Old 06-02-16, 10:58 PM
FIGS
The Maker
FIGS's Avatar
Originally Posted by 5280ISF
Mike,
Thanks.
They are a patented pattern called "open slot" where the venting happens in the slot profile
We can provide a 4 pot rear, but I think the real upgrade is in the piston technology and calipers over stock. There a lot of configurations we can offer as custom we just have the most common suggestions on our site at the moment.
Mike
__________________
Old 08-05-16, 09:38 AM
mindcrime
mindcrime's Avatar
what's the price on the front rotors?
Old 08-08-16, 11:55 AM
s4chico
s4chico's Avatar
www.shopfigs.com/v3/2psrtr-ISF-FRONT
Old 09-13-17, 11:36 AM
FIGS
The Maker
FIGS's Avatar
10 more sets of rotors are due next week. Just letting you all know, we go through batches of these and they are not always in stock. Also in addition to RB pads with work well for street applications, we also have augmented our pad offerings to include G-Loc pads. Mike
__________________
Old 11-04-17, 08:12 AM
Leander311
Leander311's Avatar
Mike,
All your links are broken FYI.
Thanks,
Nick
FIGS (11-07-17)
Old 11-04-17, 01:10 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,842 Likes on 2,330 Posts
Originally Posted by Leander311
Mike,
Thanks,
Nick
Links fixed.
FIGS (11-07-17)
Old 11-07-17, 08:22 AM
FIGS
The Maker
FIGS's Avatar
Links fixed.
Thanks, still working through the redirects from the old host. We recently migrated and its been a pain. Much appreciated.
Mike
__________________
Leander311 (12-04-17)
Old 11-07-17, 04:09 PM
ZaxF
ZaxF's Avatar
I ran this full setup on my ISF before I sold it. The braking power over the already stout OEM brakes was tremendous. Running on a track as technical as Atlanta Motorsports Park, I found that i could brake significantly later into the braking zone than I was used to. I think I actually text Mike while I was at the track to tell him that on my first session I had to get back on the throttle because the car stopped so much faster that I was well ahead of turn in and not carrying enough speed. I was using the Gloc Racing pads as well.
If you want the highest performing brakes for the ISF, these are your huckleberry.
FIGS (11-07-17)
Old 12-20-17, 04:21 AM
gtrevels
gtrevels's Avatar
Mike,
Are there any "End of Year" deals available for a set of Front 2 piece rotors and pads for track setup? My fronts need to be replaced before my next track day.
Cheers,
gtrevels
Old 12-20-17, 08:42 PM
FIGS
The Maker
FIGS's Avatar
Originally Posted by gtrevels
Mike,
Cheers,
gtrevels
Thanks for the order today. They are marked down a bit more than usual through the end of the year.
Mike
__________________
Old 02-25-18, 01:20 AM
HyunR
HyunR's Avatar
is this rotor work with oem brake pad 100%?
Quick Reply: New Product Combo 2P rotor kits (Front and Rear) packages and 15/14" 2P floating BBK packages.
