Cleaning the smog sensor
Old 06-12-15, 04:31 AM
Lavrishevo
Lavrishevo's Avatar
Default Cleaning the smog sensor
Hey guys,
I believe your 460's share the same style of smog or carbon monoxide sensor as we do. Anyway, I wanted to share our thread on the 430 side as they can easily be cleaned for increased performance. They literally snap apart and I just used standard dish soap on the filter and MAF or electronic cleaner on the sensor itself. Mine had never been cleaned and was filthy when I first cleaned it.
https://www.clublexus.com/forums/ls4...ml#post8410737
Old 06-12-15, 04:59 AM
greg3852
greg3852's Avatar
Wow that thing was dirty. Thanks for the post. If I ever get around to driving my car again, I'll have to check it out. Summer is motorcycle time.
Old 06-12-15, 04:09 PM
hms09
hms09's Avatar
Can anyone give directions on how to remove on an 07 460? I dont even know where it is. Mine does not work at all and from reading these posts I'll bet its really dirty.
Thanks
Old 06-12-15, 05:28 PM
Lavrishevo
Lavrishevo's Avatar
Did you check the link? Look at the first page. Yours should be located in front of the radiator. Since I do not own a 460 I cannot tell you exactly. On the 430, it right next to the horn in front of the radiator. One bolt holds it in place. Maybe a fellow member can confirm this or post a pic.
Old 06-14-15, 08:22 PM
Chaos236
Chaos236's Avatar
Thanks
I tried it but need ALL the steps(none to small) as how to get it out,
Thanks.
Old 06-15-15, 04:57 AM
Lavrishevo
Lavrishevo's Avatar
I found this other thread. Does not give much more info. Hopefully a fellow owner can chime in. Can you post a pic of how yours is mounted? I'm surprised other are not jumping all over this. It is an easy diy and increases the performance of the sensor so you don't breathe in fumes.
https://www.clublexus.com/forums/ls4...og-sensor.html
Old 09-19-17, 06:26 PM
DavidinCT
DavidinCT's Avatar
Mine filter is shot (falling apart), who can get another filter ? Anyone know what a good replacement filter for it ?
Old 09-21-17, 11:41 AM
213374U
213374U's Avatar
Hmmmm, gonna have to check this out this evening.
DavidinCT (09-21-17)
Old 10-16-17, 08:05 AM
DavidinCT
DavidinCT's Avatar
Anyone figure out a good filter to replace in the smog filter ? it's working so so, I am almost thinking about replacing the whole thing if I cant find a filter. I know a filter should cost under $1 but, I cant find a good replacement for what is inside it.
Old 10-16-17, 12:24 PM
213374U
213374U's Avatar
I was careful not to destroy mine when I pulled it out. Used the compressor to blow all dust out of it then washed with soap and water and reinstalled. Not sure if it made a difference but it's so easy to do it's one of those "why not?" kind of things.
Old 10-17-17, 09:51 AM
DavidinCT
DavidinCT's Avatar
I picked my car up used, it looks like this was done to it a few times... it is falling apart, I need to replace it... this is why I am looking for a replacement. Is there a part number for the filter that I can get ?
Old 10-17-17, 10:34 AM
Lexuslsguy
Lexuslsguy's Avatar
Use a cheap furnace filter from Walmart or wherever and cut to size. Kind of cool seeing an old familiar thread brought back to life.
Old 03-19-21, 11:17 AM
Dolph1
Dolph1's Avatar
Just cleaned mine. 13 AWD L. I did it without disconnecting the wire harness as there is plenty of room to work. Car has around 46k on it and as you can see from the pic there was plenty of dirt in the filter, particularly near the air intake. Might have also been some spider eggs in there at one point.
Morfeeis
08-13-17 01:18 PM
topgun129
13
11-19-14 09:50 PM
PFB
05-15-14 08:42 PM
jjmch
RX - 1st Gen (1999-2003)
03-28-09 11:28 PM
Rtstrider
11-11-08 08:37 AM
Quick Reply: Cleaning the smog sensor
