Tow hitch bumper cover
Old 02-11-15, 04:08 PM
Somun
Somun's Avatar
Default Tow hitch bumper cover
Hello all,
On the used 2013 GX 460 that I recently purchased, the previous owner had added a tow hitch (not the OEM style, but the simple, smaller one (class III only?)).
He stated that he did the installation himself, and it appears that he broke many of the tabs on the cover portion that goes right above the hitch itself.
Since the tabs have been completely broken off in several places, it can't be repaired, but needs to be replaced.
I'm having a hard time figuring out exactly what is the replacement part number required for this trim piece.
I have found an online diagram: http://lexus.sewellparts.com/images/...000/522199.jpg
The problem is that it appears that the part number is the same for the part for towing and without towing (in this case, #52169B). I assume the part for a tow hitch has some sort of different in shape, but if they both have the same part number, how am I to order the correct unit?
In addition, in the diagram, there is another part (under the "towing" picture) with this part number: #52169C. I'm not sure what that part is for, but seems to imply it is needed?
Anyone have recommendations for the parts that I need to order?
Somun
Somun is offline
Old 02-11-15, 05:41 PM
JDSTL
JDSTL's Avatar
I have a 2014 but to me it looks like the only difference is that part that is used for vehicles with the hitch. The outer cover is the same, but I believe you'll have to get it painted.
JDSTL is offline
Old 02-11-15, 05:53 PM
tecman
tecman's Avatar
Different part numbers ending with 40 and 50.
http://www.ebay.com/itm/Lexus-TOYOTA-OEM-10-13-GX460-Rear-Bumper-Lower-Cover-5216960150-/221676057464?_trksid=p2054897.l4275
http://www.autonationpartsdirect.com...xus/5216960140
50 shows with hitch here.
http://www.oemautopartsandaccessorie...57eaf7131cab8/
tecman is offline
Old 02-11-15, 06:24 PM
11GX460
11GX460's Avatar
Originally Posted by Somun
Hello all,
Somun
Do you mind posting a photo of what that area looks like without the cover? Thank you.
11GX460 is offline
Old 02-12-15, 09:31 AM
Somun
Somun's Avatar
Default Picture of broken piece
Here is a photo I took this morning of the piece in question. As you can see, the tabs are broken, so it won't fit flush anymore. I'm afraid it will fly off at some point...
Somun is offline
Old 02-12-15, 10:59 PM
Capirato
Capirato's Avatar
If it were me, I would glue it on with calking. Hold it in place with some tape while it dries.
~ Cap
Capirato is offline
Old 02-13-15, 06:28 AM
jaleels
jaleels's Avatar
The covering is very flimsy. I tried to remove the covering once and I noticed that the clips are very poorly designed. There is a built-in hitch for light items like a bike carrier behind that cover. Many people are buying the trailer hitch for their vehicle to carry items like a bike rack. A bike rack can be installed in the receiver that came with the GX. The trailer hitch that is under the vehicle is for towing larger items like a trailer.
jaleels is offline
jshuff (01-08-21)
Old 02-13-15, 09:11 AM
Somun
Somun's Avatar
Does anyone know what is the part number to order a replacement part?
Glue and tape will be my last option, but I would rather just get a fixed unit.
Somun is offline
Old 02-13-15, 11:58 AM
Capirato
Capirato's Avatar
The number is 52169B. But you have to designate a color.
You're still better off by putting some sealant on the broken clips, then taping the cover until the sealant dries.
~ Cap
Capirato is offline
Old 02-13-15, 05:49 PM
11GX460
11GX460's Avatar
Thank you for posting this picture. Could you please post one without the cover on? By the way, I think replacing the entire piece with a brand new one is the way to go, but if you never want to remove that piece again, then JB Weld it.
11GX460 is offline
Old 02-16-15, 11:22 AM
Capirato
Capirato's Avatar
Somun, if the cost is not an issue, go to a Lexus Parts Dept. and order the cover.
~ Cap
Capirato is offline
Old 02-27-15, 06:21 PM
Somun
Somun's Avatar
Default Replacement part
I found the correct part, and ordered it; only $38 but unpainted.
COVER, RR BUMPER, LW
[GX460 | 2013]
Replaced by: 52169-60150
Here is a picture showing how damaged the original was:
New part (unpainted):
Somun is offline
Old 02-28-15, 08:18 AM
Randy B
Randy B's Avatar
Default What is behind that cover?
Since it's not a hitch, what is behind that cover? Purely access to the spare?
Randy B
Randy B is offline
Old 02-28-15, 12:40 PM
Capirato
Capirato's Avatar
Somun: Why didn't you order it painted ??
~ Cap
Capirato is offline
Old 03-02-15, 11:20 AM
Somun
Somun's Avatar
I thought that it was supposed to be painted; already sent a question to the place I ordered it from and await the answer.
As for what is behind the cover, I will take a picture and post it. As far as I can see, there is no need for this part to be accessible, so not sure why the previous owner felt the need to take it off.
To access the spare, there is a little plastic piece you pop off on the bumper, and then insert a rod to lower the spare.
Somun is offline
Quick Reply: Tow hitch bumper cover
