NY 5K WHITE Vleds DRL LIGHT BULBS 9005
Old Mar 17, 2014 | 06:09 PM
Raybean's Avatar
Raybean
Default 5K WHITE Vleds DRL LIGHT BULBS 9005
Selling a pair 5k white led 9005 bulbs made by vleds. These can be used as drl. Great if you wanna get rid of the ugly amber color stock drl. They are super bright. Had for 4 months. Upgraded my headlights no longer need. New style CREE leds. Retail for $60 on the vleds website. I am asking for SOLD
Note: The drl and high beams is the same bulb so your high beams will not be as bright, but they are still bright so if you live in a place or if you rarely use your high beams you wouldn't have any problems with these.
http://www.vleds.com/shop-bulb-numbe...45-1-pair.html
http://www.flickr.com/photos/weis11/13232267433/
Old Mar 17, 2014 | 07:16 PM
TheVille's Avatar
TheVille
So with these on are the high beams not going to work?
Old Mar 18, 2014 | 05:31 PM
Raybean's Avatar
Raybean
bump bump!
Old Mar 18, 2014 | 11:10 PM
nippiexfam's Avatar
nippiexfam
do you have any pictures with these installed on the car at night?
Old Mar 19, 2014 | 07:49 AM
Raybean's Avatar
Raybean
i do not, but there are pictures on the vleds website.
Old Mar 19, 2014 | 08:42 AM
lilStig's Avatar
lilStig
will the high beams no longer work?
Old Mar 19, 2014 | 09:06 AM
dannyboy26's Avatar
dannyboy26
Not as they should, this give out 850lm which is plenty to light up bright but not enough for high beams which are usually 1200lm
Old Mar 19, 2014 | 02:29 PM
tboo72's Avatar
tboo72
Wait, so our DRL are also the high beams? I thought the ISs had bi-xenon headlights?
Old Mar 19, 2014 | 02:36 PM
dannyboy26's Avatar
dannyboy26
Yes sir you are correct, when used as DRLs the output is very subtle and then they turn off when you use your headlights and thats when they become your highbeams
Old Mar 19, 2014 | 02:38 PM
nippiexfam's Avatar
nippiexfam
I don't think they are bi-xenon. For sure the DRLs are the high beam bulb. You will lose high beam functionality.
Old Mar 20, 2014 | 12:42 PM
Raybean's Avatar
Raybean
bump bump!
Old Mar 20, 2014 | 12:56 PM
sm1ke's Avatar
sm1ke
The IS has bi-xenon projectors. When the DRLs are functioning as DRLs, they are operating at something like 50-75%. When you hit the highbeams, the DRLs output at 100%, and if your lowbeams are on, the cutoff shield will shift to throw more light on the ground. You can see it if you park your car against a wall with your lights on (at night, obviously) and hit the highbeams.
Old Mar 20, 2014 | 08:03 PM
9aristo's Avatar
9aristo
whoever is thinking about this - you will need this as well:
http://www.vleds.com/9005-in-line-ca...r-adapter.html
Aristo722
Nov 2, 2015 09:44 PM
chromedome
14
Feb 18, 2015 02:16 PM
Dustoff
Oct 11, 2011 11:17 AM
Synetix250
Jun 7, 2010 10:09 PM
Supraman16
Lighting
Dec 20, 2008 03:55 PM
