I've seen similar offsets on the F, and I think it is quite aggressive without running camber and/or skinnier tires. But it is doable. I would at the very minimum roll the rears. The fronts have a little bit more room, but I'd first try these wheel sizes with stock tire sizes first. This way you have a feel for how much more you can increase in terms of tire tread if needed.
im thinking 245/35/19 in the front
275/30/19 in the rear.
im running almost the same exact set up now except for the offset
19x9.5 + 22 on 255/35
19x10.5 +30 on 275/30
lowered on BC coils, I has to roll both front and rear fenders because if I didn't id rub a little bit. but you should be ok.
Reason: ............
