CA WTT: My Ichiba V2 25mm Spacers for your V2 10mm
Old Jun 18, 2011 | 05:23 PM
xxjtp1xx's Avatar
xxjtp1xx
Default WTT: My Ichiba V2 25mm Spacers for your V2 10mm
Hi, I have a set of 25mm Ichiba version 2 Spacers. These are the fairly new with maybe about 10K miles on 'em. I'm looking to trade these for 10mm or 15mm Ichiba v2 spacers (same brand and version if possible). These are a great set if you are trying to go for the aggressive look. Locals preferred, So Cal, 626 area. Pm me!! Thanks!!
Description from their webpage:
Version II wheel spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. Each wheel spacers are two pieces design with pressed studs. Now it's time to bolt-on without any swap studs hassles. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
Spec:
Bolt Pattern: 5/114.3
Center Bore: 60.1
Thread: 12x1.5
Attached Thumbnails WTT: My Ichiba V2 25mm Spacers for your V2 10mm-25mm.jpg
Old Jul 25, 2011 | 01:50 PM
xxjtp1xx's Avatar
xxjtp1xx
bump......
ab2design
Club Lexus Vendor Marketplace
708
Feb 4, 2015 08:18 PM
xrsracer
Wheels and Tires Classifieds
Mar 1, 2012 07:27 PM
2GSonAir
Apr 25, 2011 12:49 PM
VNN326
Aug 19, 2008 10:28 AM
