Check VSC light/traction control
Old 03-20-11, 10:39 AM
waynedog
waynedog's Avatar
Default Check VSC light/traction control
On my 04 LS430, I recently had the Check VSC warning message come on and at the same time the "Traction Contol Off" light came on. When I push the Traction Control button, it will not turn it on or off - it stays off.
What could be causing this? Probable fix/cost?
Old 03-20-11, 11:05 AM
CarGuy89
CarGuy89's Avatar
You've discovered what I failed to do...get rid of both VSC and trac control for good! We should trade cars...lol
To (attempt to) answer your question, it sounds like it might be a burnt fuse issue.
Old 03-20-11, 02:22 PM
Kansas
Kansas's Avatar
A long list of issues - some cheap to fix, some not so cheap - can cause the VSC warning and VSC to turn off. Many of the issues seem unrelated to VSC -- maybe the warning comes on just to get our attention. The first step is to see if there are any stored error codes.
I suppose you could reset the VSC and see if the warning light comes on again. The procedure for resetting the VSC on an LS430 with a jumper wire has been posted on this forum in the past.
Old 03-20-11, 04:48 PM
Bocatrip
Bocatrip's Avatar
The previous owner of my car told me of the traction control off light coming on and he took the car to Lexus. They found the timing belt was slightly off and they had to remove and reinstall it. End of problem.
Old 03-21-11, 12:22 PM
LucidSnow
LucidSnow's Avatar
vsc off light warning is like so random, so many possibilities but it disables abs/vsc/and laser cruise control when it happens. hope u get it fixed. dealership to check it out is best bet.
Old 07-18-19, 11:59 AM
Bsavage
Bsavage's Avatar
Today is my lucky day I warmed up the car drove about 3 miles no cel lights than after I turned on the ac for 2 mins check vsc message came on any ideas where to start looking ? As of right now the car feels normal
Old 07-18-19, 12:35 PM
ls430w140
ls430w140's Avatar
Techstream. Or OBD scanner with ABS and other supported module. There is really no other way to know what's going on unless you check the DTC. If you have access to Techstream, try to begin with full Health Check.
Local auto repair shops may offer to quickly do electronic diagnostic for a reasonable fee ($20 and more).
Old 07-18-19, 12:56 PM
Bsavage
Bsavage's Avatar
I just used a scanner basic one I’m getting 4 codes p0441, p0446, p0455, p2418, there all evap codes hmmm
Old 07-18-19, 01:09 PM
Bsavage
Bsavage's Avatar
I reset the codes popped the hood and saw this somehow disconnected hopefully this was the cure for me how could that evap hose slip off it was pretty tight to put back on without squeezing the metal clamp
The hose going from the vsv to this metal pipe
The following 2 users liked this post by Bsavage:
infojunky (11-22-19), ONashir (09-18-21)
Old 07-18-19, 02:01 PM
Bsavage
Bsavage's Avatar
Update after driving 30 miles no codes reappeared its weird how that hoes slipped off I’m stumped
Old 07-18-19, 05:09 PM
ls430w140
ls430w140's Avatar
I would replace EVAP rubber hoses and clean the valve with WD-40.
Old 07-19-19, 07:54 PM
Bsavage
Bsavage's Avatar
I went to oriley’s and got 7 ft of vacuum hose for $5 I changed out most of the top I just couldn’t get to the part under the power steering res I’ll have to try to tackle that another time
Old 08-14-19, 06:11 AM
lr2017
lr2017's Avatar
My LS 430UL VSC light came on yesterday when I was driving fast while entering highway, a day before was I was experiencing slight loss of power so I had to turn on ECT power button, i felt like it still missed the oomph it used to.3 days prior to that I had taken to dealer who told me that front air shocks were bad and leaking into alternator, but he did not give the impression of urgency. Now I am to replace two front and two back air shocks and remedy the VSC. I am thinking of taking it to either a Toyota dealer or a repair shop that has experience with fixing Lexus. I looked up the threads for air shocks and either i) I will try to get the air shocks from UAE warehouse or ii) Arnott's new air shocks or iii) replace with coil, in order of my preference, have mechanic do all of the above.
Does that sound like a reasonable way to go about ? Is there easier way to find non-dealer lexus specialist shops? I am in Hicksville, NY.
Thanks
Old 10-07-19, 10:25 PM
lr2017
lr2017's Avatar
Mechanic said VSC light was on due to mass air control sensor bad, replaced it light gone, oomph back, but mileage dropped.
Now looking to replace air struts, amazon (3rd party) is selling genuine lexus part for $900 while the dealer is quoting $1800, ebay, megazip.net all are around $900, I don't know what is the deal here, why are they cheaper, hope they not the QC failed parts. Any thoughts, experiences?
Thanks
Old 10-08-19, 06:56 PM
Frank0616
Frank0616's Avatar
Thanks
Hey do you still have those air strut?
Quick Reply: Check VSC light/traction control
