MN F/S: SC300 and 1JZGTE Parts
PARTS FOR 1JZ-GTE @ 68k miles:
CT12A TURBO Assembly WITH EXHAUST MANIFOLDS, INTAKE SIDE FOR TURBO, Oil lines and other hardware. Only the turbo picture is listed but you'll still get all the other stuff. Turbo has normal shaft play-----$300
Map sensor -----$50
Intake manifold with throttle(Automatic transmission only)----$75
IAC (IDEL AIR CONTROL VALVE) -----$100
**SOLD**Alternator FOR 1JZ-----$75
TPS (Throttle Position Sensor)-----$75
Knock Sensor-----$50
Front oil pan set-----$200
Torque Converter-----$75
Flywheel flex plate. Gears in great condition (for Torque converter)-----$20
PARTS FOR SC300 2JZGE @ 132k miles:
Charcal Canister-----$20
Fuel Pump ECU-----$75
Engine ECU-----$100
2x Cam Shafts with cam gears-----$75
**SOLD**Cylinder Head-----$100
Intake manifold with throttle-----$40
Exhaust manifold-----$40
**SOLD**W58 manual transmission-----$250
Front Drive Shaft for W58-----$ 50
ECU 5 speed only---------$100
**SOLD** Flywheel-----$25
AC compressor with clutch-----$50
Power steering pump with pully-----$50
Distributor Assembly-----$50
Valve cover-----$20
MAF sensor assembly-----$50
Stock 6x Injectors and rail-----$50
**SOLD** Ignitor-----$20
Last edited by vangb2; Aug 27, 2010 at 10:44 AM. Reason: Just sell what you have listed please without issue before you post more
