Installing Supra TT Calipers.
Old 04-15-10, 05:03 PM
duby1
duby1's Avatar
Default Installing Supra TT Calipers.
I'm picking up a set of supra TT brakes.... Is it plug and play? What would i need?
And yes... For those of you say use "search" I have, but some people say i need to sand down a bolt... install a RCA... and other people say it's plug and play....
I want to know the people that do have the calipers and how did they install it...
Old 04-15-10, 05:07 PM
vwynn
vwynn's Avatar
its a PNP thing.
2 ways.
1). bend the dust shield till the calipers bolt on.
2). remove the dust shield n bolt on.
Thats pretty much it
edit:
what you need.. on top of my head
17mm to remove caliper bolts
14mm to remove brake line bolt.
Old 04-15-10, 05:19 PM
Kyle Harty
Kyle Harty's Avatar
From everything I've read, the Supra TT's are plug and play other than the dust shield like was said, it's the LS400's that require an RCA or shaving.
Old 04-15-10, 05:22 PM
vwynn
vwynn's Avatar
did mine a week or so ago by bending the shield.
Old 04-15-10, 05:24 PM
duby1
duby1's Avatar
Hmm, looks good. Did you paint it?
and... What else would you need? The brake liner? or can you use our oem ones? is 300 a good price?
BTW, can you tell the difference between this one and the OEMs? like go and going....
Old 04-15-10, 05:26 PM
vwynn
vwynn's Avatar
yea. high temp paint.
n HELLZZZZ YEAaaa. my OE brakes sucked hardcore... depends on the pads you get but im super happy with my brakes.
Old 04-15-10, 05:42 PM
duby1
duby1's Avatar
Great shiieieeeet,,, Then i can't wait to install mine on...
Old 04-16-10, 05:41 AM
Rock-a-Lex
Rock-a-Lex's Avatar
Nice work! Question, I know that the Supra calipers are heavier than the LS400 but are they heavier than the stock GS brakes also? Also, someone correct me if I'm wrong but aren't the supra rotors a little larger than the LS400 rotors also?
This is what I gather from both setups:
Supra brakes
PROS
Plug 'n' play setup
Larger rotors
More variety of aftermarket rotors
More variety of aftermarket brake pads
4 pot calipers (moved from cons)
CONS
heavy calipers
more expensive setup
require 17" or larger wheel
___________________________________________________
LS400 brakes
PROS
2 pot calipers
lightweight aluminum calipers
less expensive setup
requires 16" or larger wheel
CONS
requires RCA or shaving/rolling of fenders and tie rod ends
smaller rotors
not many aftermarket brake pads available
Is this right? Kind of sucks because it looks like a draw...pros and cons of each. In any event EITHER ONE is MUCH better than stock!
Old 04-16-10, 06:20 AM
benbuilt4u
benbuilt4u's Avatar
wasnt there just a post saying supra pads fit in the ls calipers? im pretty sure but couldnt find it.
Old 04-16-10, 08:38 AM
zenki300
zenki300's Avatar
Supra brakes
PROS
Plug 'n' play setup
Larger rotors
CONS
1 pot calipers
heavy calipers
LS400 brakes
PROS
2 pot calipers
CONS
smaller rotors
From what I remember, stock GS calipers and Supra calipers weigh almost the same. The main difference is that the supra caliper is 4 pistons and the stock GS is 2 pistons. Also the supra rotors are a little bit bigger, which is why you have to remove the dust shield to fit them in. Aside from that, they should bolt right in. You won't need to replace the stock GS brake lines either if installing the supra brakes, but it won't hurt to buy some steel braided lines.
Old 04-16-10, 09:44 AM
97JZA80
97JZA80's Avatar
How much difference over OE are we talking about? I just put my wheels on and I feel like my stopping distance is now much greater.
So I am contemplating an early Big Brake Kit for my supra so I can get the regular brakes onto the GS to help.
Old 04-16-10, 10:11 AM
maxinGS
maxinGS's Avatar
do these fits with our stock 16in wheels?
Old 04-16-10, 10:28 AM
Kyle Harty
Kyle Harty's Avatar
From what I've gathered and rock mentioned in his post the Supras need 17's, the LS400's will work with stock 16's and a 15mm spacer. Just make sure there aren't any balancing weights on the part of the wheel that will need to clear the brakes. I found that out the hard way when I test fitted the other day.
Old 04-16-10, 11:39 AM
vwynn
vwynn's Avatar
from larger rotors + Surface area + 2 additional pistons pushing at better braking pads.. ide say its a lot better. especially at high speeds :]
Old 04-16-10, 06:52 PM
V8_MPG
V8_MPG's Avatar
Another good alternative for wheel setup is to get a set of G35 18" wheels. That's what I use on my GS400 with Supra TT brakes for winter.
Quick Reply: Installing Supra TT Calipers.
