Help for 06 GS430 Front Bumper Remove!
Old 01-14-10, 11:12 PM
ashley1977
ashley1977's Avatar
Smile Help for 06 GS430 Front Bumper Remove!
Can anyone provide me with some links or instructions on how to remove the front bumper? I am trying to get the front bumper repaint, hope do this can save some money! And is it hard to put the cover back? Thanks for the answer
Old 01-15-10, 05:41 AM
IXI187IXI
IXI187IXI's Avatar
ive had mine off several times. very simple.
1) pop the hood and remove the rad cover and side engine covers along the fender.
2) there should be (5) bolts along the top, i believe maybe its (3). 1 or 2 around the head lights and 1 at the center above the lexus logo.
3) remove the push pins and screws in the wheel well for the front liner that attach to the bumper.
4) behind the liner is a bolt on each side going through the bumper and fender holding them together.
5) under the car, there are (6) i believe screws for the bottom of the bottom holding it to the front air dam and wheel lines.
6) remove bumper.
once all the bolts are out, be a little carefull around the corners by the headlights where the bumper meets the fender. its a little snug and kinda snaps in.
if i missed anything, someone feel free to chime in.
Old 01-15-10, 05:01 PM
passnu2
passnu2's Avatar
Here you go
what are you doing
File Type: pdf
jul3per (01-29-18)
Old 01-15-10, 05:35 PM
rominl
exclusive matchup
rominl's Avatar
Originally Posted by passnu2
Here you go
what are you doing
he mentioned he's going to paint it?
Old 01-15-10, 05:39 PM
passnu2
passnu2's Avatar
oops...guess I skimmed right over that.
Old 01-15-10, 07:06 PM
derricklee
derricklee's Avatar
Is disconnecting the cable from battery really necessary?
Old 01-16-10, 11:25 PM
ashley1977
ashley1977's Avatar
Finally removed the front bumer with no problem. Thank you IXI187IXI and passnu2. =p
Old 01-29-18, 11:46 AM
jul3per
jul3per's Avatar
Thumbs up Thanks
Here you go
what are you doing
This is very close to what I was looking for. I'm planning on removing the front bumper to check for a leak in the head light washer line...... Thanks again for providing this diagram.
By any chance can any one become member to TIS? No special certificate is required or license to get access to the repair manuals?
Old 02-21-18, 11:22 AM
passnu2
passnu2's Avatar
Thumbs up
Glad to see it's still helping members out!
Old 06-15-19, 07:34 PM
Kton
Kton's Avatar
Here you go
what are you doing
So I tried following this instruction but on the top there are two screws that I just cannot unscrew. They are situated right on top of the DRL's and keep popping back in place when I try to turn them out. Anyone know what I'm talking about?
The piece it is attached to gives instructions on how to adjust headlight level, all plastic.
Mine is a 2006 GS 430 if it matters.
Old 06-16-19, 06:32 PM
Kton
Kton's Avatar
for reference, these are what I'm talking about.
Old 06-16-19, 07:13 PM
ibidu1
ibidu1's Avatar
Sounds like your nuts are rusted/seized, spray some lubricating spray on the bottom of the bolt. Then grab some needle nose pliers on the bottom and see if you can hold the clip nuts to keep them from not spinning.
Old 06-16-19, 07:29 PM
Kton
Kton's Avatar
good point, Odd that *both* are seized in the same way. I also can't get to the spinning nut because it's sealed off in what looks like a sealed rectangular box.
*sigh*
Old 06-17-19, 03:45 AM
ibidu1
ibidu1's Avatar
*sigh*
Try soaking it from the top and bottom for a day and try and see if it loosens up. If you cant reach the inside of the clip nut, then you might be able wedge a screw driver against the plastic and the nut.
As a last resort, grab a drill and start off with a tiny drill bit. Drill a pilot hole just enough to go deep enough to clear the head of the bolt, then use a larger drill bit say a 6mm to finish off the final drilling. That should allow the bolt head to come clean off without damaging the plastic. You will need to go to the dealer and order a new bolt and nut clip.
Vi-Tuyen
LX - 3rd Gen (2008-2021)
03-24-24 02:43 PM
Crim
08-24-16 07:28 AM
KWATCH
07-22-14 07:10 AM
Scweet14
10-15-11 10:32 PM
dsabc2867
04-10-10 03:40 PM
Quick Reply: Help for 06 GS430 Front Bumper Remove!
