If normal, where does your temperature gauge needle read?
If operating correctly, where does your temperature gauge needle read?
I have a 99 LS and mine normally reads right on the third mark. i.e. the mark that is just below middle.
My coworker thinks my thermostat needs replacing but he doesn't have and LS...he has a 2003 Tundra.
Have a 92 and that is where mine falls as well. Test for thermostat blockage,, warm the car up to temperature,, go under the hood and locate the 2 radiator hoses, both hoses should be equally as hot to the touch. If one hose(normally the upper) is SUPER hot, while the lower one is hot but can be gripped(for a short period,,don't want you burning yourself) with your hand; thermostat is not working correctly and should be replaced.
Question: Is there anything to be concerned about if the temperature gauge is not consistent? What I mean is, is it normal for the temp. gauge to fluctuate somewhat?
I'm driving in 34 degree temperature and it seems that the temperature gauge will fluctuate a bit. It never went to a point where I was concerned with overheating, but I have a feeling that the temp gauge fluctuating is not normal. My dad's '99 4Runner's temp gauge is solid no matter the temperature. Same goes for my mom's '05 Accord V6.
Is there something wrong with my cooling system?
By the way it is a 1997 LS400 with 234,500 miles. The timing belt, waterpump, thermostat, and coolant was done at 183,000 miles.
My 90 i just had to fix alot of issues on and now my normal temp guage is about 3 slots under HOT! could this be my temp sensor also? and would a coolant temp sensor make the car have a faint miss in it?
Where it sits is not usually a concern as long as it warms up and stays consistent with a little variation for driving conditions (a little equals like 1/8th of an inch?). It's the job of the termostat to stay closed when too cool and open when keeping the engine cool. If is warming up and going all the way hot something is wrong, stop driving it and fix it... if it's warming up and then varying only to the cold side the termostat is stuck open... this is less dangerous but the engine loses efficiency. All in all don't read to much into where your gauge sits in relation to other's people gauges as long as it's consistent. This is also why new cars are programmed to sit dead center as long as the reading is within a certain range then go all the way cold or hot as it goes out of range..
I'm guess by '97 the LS400 was set to stay consistent as well? Meaning I should get the car looked at?
