TX FS: 2JZ-GTE VVTi Stock Twin Turbos + Turbo Manifold + Turbo Piping
Selling the 2JZ-GTE VVTi stock twins. I have a set of these I'm getting rid of. It came out of an extremely clean low mileage engine. You can see how clean the engine was from the pictures below. The engine had very minimal sludging and the coolant left in the block was still bright pink! The turbos have near zero shaft play since they are such low mileage.
If you need any of the associated vacuum hoses/lines please specify to me. I threw everything from the engine into a big pile.
I'm selling what you see in the first picture for $250 + shipping(going to be approx $50, it's a heavy item to ship).
Well, I can't say for sure since I've never tested it myself. I don't see why not though. I don't think Toyota ever changed the turbo setup throughout the years for the 2JZ-GTE. I just looked up the part numbers for the manifolds, hoses, etc and it's all the same for the VVTi and non-VVTi motors. Worse case scenario, you can just swap the turbos over to your GTE non-VVTi manifold but I don't think that will be necessary. These turbos are in very good condition with near zero shaft play.
Note: Most people online sell only the turbos and manifold for $250 range. I'm selling all the rest of the upper pipes, shields, etc for $250. Other sellers usually charge an extra $150-200 on top for those extra charge pipe pieces.
I believe they are ceramic compressor wheels. It spools up faster with better engine response. Only downside is that you can only push the JDM twins to around 400rwhp, the USDM twins can be cranked to 450-75hp or more.
For those of you guys asking. This setup is for a 2JZ-GTE. It will take quite a bit of modification to fit it on a 2JZ-GE.
Yeah, I'll part those out. But not for cheap! I will sell the complete head for $1000 shipped. If you just want the valve covers and coilpack cover then it will be $600. These are RARE parts so I'm not selling them cheap. I really have no desire to sell it because I was planning to use this in my 3.4L stroker race spec engine I'm building. It's extremely clean so that's the main reason I want to keep it. Normally you will never find a GTE head in this clean and nice of condition. BUT...if the price is right I'll sell anything
okay thank but if I was to purchase a stock twin Turbo kit from the GTE would it be a easy installed on the ge
