Well I never thought Id be doing this but im putting my babies up for sale, its time to move on to bigger and better things (actually smaller and wider haha).
fronts: 19x9.5 +20 high disk bbk friendly
rears: 19x10.5+20 med disk
perfect ls400 fitment imo.
front two have moderate curb rash and lip haze from the previous owner, i would suggest getting them redone before mounting, the rears have a couple nicks but are in good shape.
come with general exclaim uhps 235/35 and 45 in the rears plenty of tread left.
one tire has its sidewall rubbed off, still holds air fine i just ride too low lol
if your interested pm me for close ups
new price!! $1800 shipped to the 48, or $1500 picked up
ShaneC, I'm a newb at wheel fittiment. If you could give some advise, It'll be great
i had 19x10+22 or was it +20 offset (one or the other) in the rear for this set of wheels in the picture. mods i had was shaved fenders. to fit these wheels all you need is the right size tires, shave fenders (gs rear fender is too thick to roll) and add some negative camber if needed (very inportant, it all depending what your ride height). these profounds extend out about 6 to 8mm more then the wheels i have in the pic above. 8mm can easily be fixed with one degree of negative camber, which is adjustable with the stock camber bolt. If you stick with the 235 series tires that come with the wheels, you probably don't have to add any extra camber. hope this gives you a better idea of how these wheels will fit. fitment will be pretty much similar to pic above or even slightly nicer. you can see still had room to go wider. so these wheels wont be a problem
as for the fronts, fitment will be the same. you will need to roll the front fender. that's pretty much it. 235 series are perfect size.
if i didn't have wheels already, i would be all over these. fitment will be on the aggressive side. it will look super dope on a GS.
