SC430 Owners Wheel Size/Offset Roll Call
Old 03-08-08, 10:13 AM
Hermosa
Hermosa's Avatar
Default SC430 Owners Wheel Size/Offset Roll Call
Based on so many questions about SC430 wheels and spacing can everyone who wants to post the following:
1. Front Rim Diameter, Width, and Offset
2. Front Tire Dimensions
3. Front Wheel Modifications Needed
4. Rear Rim Diameter, Width, and Offset
5. Rear Tire Dimensions
6. Rear Wheel Modifications Needed
7. Picture of your setup that exhibits the offset of both wheels
Please keep chit chat to a minimum so we can keep the actual details of everyone's setup at the top.
Wesley430 (10-15-21)
Old 03-08-08, 10:16 AM
Hermosa
Hermosa's Avatar
STOCK SETUP
Front Rim Diameter, Width, and Offset: 18x8 +45
Front Tire Dimensions: 245/40R18
Front Wheel Modifications Needed: None
Rear Rim Diameter, Width, and Offset: 18x8 +45
Rear Tire Dimensions: 245/40R18
Rear Wheel Modifications Needed: None
Picture courtesy of Talwang
Old 03-08-08, 10:21 AM
Hermosa
Hermosa's Avatar
Stock Wheels with +25mm front / +25mm rear
Front Wheel Modifications Needed: +25mm front offset
Rear Wheel Modifications Needed: +25mm rear offset
Courtesy of DSIMO
Old 03-08-08, 10:34 AM
Hermosa
Hermosa's Avatar
Trafficstar RTS in High Polish
Front Rim Diameter, Width, and Offset: 20x9 +18
Front Tire Dimensions: 245/35R20
Front Wheel Modifications Needed: Fenders rolled
Rear Rim Diameter, Width, and Offset: 20x11 +23
Rear Tire Dimensions: 275/30R20
Rear Wheel Modifications Needed: Fenders rolled
Courtesy of D-MAN63
Other notes:
Fronts:Inner clearance 14mm more than stock / Outer position 40mm more than stock
Rear:Inner clearance 16mm less than stock / Outer position 60mm more than stock
Old 03-08-08, 10:44 AM
Hermosa
Hermosa's Avatar
Vossen 078
Front Rim Diameter, Width, and Offset: 20x9 +25
Front Tire Dimensions: 255/30R20
Rear Rim Diameter, Width, and Offset: 20x10.5 +30
Rear Tire Dimensions: 285/30R20
Rear Wheel Modifications Needed: None but rubbing on the rears
Courtesy of 98LexSc400
Other notes:
Fronts: Inner clearance 7mm more than stock / Outer position 33mm more than stock
Rear: Inner clearance 17mm less than stock / Outer position 44mm more than stock
Old 03-08-08, 10:45 AM
PVlexus
PVlexus's Avatar
Hermosa, those Trafficstars are my favorite wheels of all time. Looks sweet
Old 03-13-08, 04:09 PM
D-MAN63
D-MAN63's Avatar
Front Rim Diameter, Width, and Offset: 20x9 +16
Front Tire Dimensions: 245/30R20
Rear Tire Dimensions: 275/25R20 D-MAN63 please confirm with PM and I will update
Courtesy of D-MAN63
Other notes:
Fronts:Inner clearance 16mm more than stock / Outer position 42mm more than stock
Hi Hermosa,
My fronts are 20 x 9 +18 offsets 245/35/20. The rears are 20 x 11, +23 offsets. 275/30/20. Thanks !
Old 04-06-16, 09:55 PM
JMal
JMal's Avatar
Default Wheel offset
Hi, wow. How did you modify the wheel?
Courtesy of DSIMO
Old 04-06-16, 10:31 PM
texsexlex
texsexlex's Avatar
...he added 25mm spacers front & back
Old 04-06-16, 10:43 PM
JMal
JMal's Avatar
Default SC430 wheel offset
Thank you. Were any steering or wheel alignment modifications required as a result of the track becoming wider and the scrub radius moving toward the inner part of the tyres?
Old 04-06-16, 10:48 PM
texsexlex
texsexlex's Avatar
...this isn't my vehicle,but I wouldn't think there were any issues. The thing you will have to pay attention to is the torque specs for the spacers, if they aren't torqued correctly or the same for each lug, you may experience a vibration. The same feel, as if the tire wasn't balanced correctly
Old 04-06-16, 11:31 PM
JMal
JMal's Avatar
Thank you very much. I think I will be going down the path of wheels with a lower offset, although in Australia we are limited to changing track width to 1 inch. I have left a message for Lexus Sydney to see if the 2006-2010 wheels have a lesser offset to those on my 2004. Otherwise I will have to go aftermarket. Thanks again. Much appreciated.
Old 04-20-17, 07:10 PM
parijss
parijss's Avatar
Default I just put 20in rims with no rub on 02 SC 430
I just bought this set
2002 sc 430 w/ velocity VW12 rims and 245/35/20 bridgestone pole position tires no rubRims
20in Velocity VW12 wheels $799 set on
eBay
5x114.3 bolt pattern
20x8.5 rim
Offset front 34-42mm
Tires
Pole position S-04
245/35/20 tires
Tire rack $950 total
Old 12-11-17, 03:51 PM
Hyper15125
Hyper15125's Avatar
eBay
20x8.5 rim
Tires
Pole position S-04
245/35/20 tires
They look great! How is the ride? Is your car stock height or lowered?
Old 12-12-17, 06:59 PM
OBP
OBP's Avatar
TSW Nurburgring
Front Rim Diameter, Width, and Offset: 18x8 +35
Rear Rim Diameter, Width, and Offset: 18x8 +35
Quick Reply: SC430 Owners Wheel Size/Offset Roll Call
