DIY: IS350 front brakes (w/o removing caliper)
Old 04-16-07, 09:47 PM
javyLSU
2IS OG
javyLSU's Avatar
Exclamation DIY: IS350 front brakes (w/o removing caliper)
Ok, so I need new front brakes. I know there's a DIY thread already here, but since I'm doing it without removing the caliper (which is what the FSM calls for), I figured I'd snap some pics and do a quick write-up for all those interested - so here goes:
The following 4 users liked this post by javyLSU:
Atgif (08-10-17), cloudstryf (05-03-17), DallasPaul (02-10-17), Lex_Giorgio (08-10-17)
Old 04-16-07, 09:48 PM
javyLSU
2IS OG
javyLSU's Avatar
This was BY FAR the easiest brake job I've ever done - much easier than past vehicles I've had. The job took me two hours, since I was stopping a lot to take pictures. Without the pictures, it would have taken me about an hour, not including the 30 minutes I spend afterward bedding my brakes. Final tally:
Brake pads: $53 shipped
Anti-squeal lube: $1.07
2 cans for brake cleaner: $6.23
Pumice hand cleaner: $1.99
So I spent two hours, and saved about $200 - hooray for me! This is something ANYBODY can do and avoid getting raped by the dealership.
Javier
The following 3 users liked this post by javyLSU:
Atgif (08-10-17), Lex_Giorgio (08-10-17), skur (06-16-23)
Old 04-16-07, 09:57 PM
IS_NIICE
IS_NIICE's Avatar
is there any reason in particular you didnt do the free tsib? thanks this will come in handy for the future.
Old 04-16-07, 10:01 PM
javyLSU
2IS OG
javyLSU's Avatar
Because 1) I have 19,000 miles on my brakes and wouldn't feel right taking my car in for them to "fix" a problem I don't have, and, 2) I don't care about the brake dust - I like the OEM pads.
Javier
Old 04-16-07, 10:11 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,845 Likes on 2,332 Posts
There was still a lot of life left in those pads. Minimum spec is 1mm. Looks like you still had 2mm to go before minimum spec, so you had another 4k miles or so had you chosen to wait.
Did you measure your disc thickness?
Old 04-16-07, 10:15 PM
javyLSU
2IS OG
javyLSU's Avatar
Yeah, I noticed I still had some life left, but they were squealing a good bit lately, so I decided to go ahead and change them out. By the way, the 19,000 miles I got out of my OEM brake pads includes several trips to the drag strip and mountain/canyon runs, and I still had some life left, as you can see - so I'm happy with the performance of the pads. AFA measuring the disc thickness, I'll be getting new rotors in a few months, so I didn't bother to measure them.
Javier
Old 04-16-07, 10:26 PM
aira
aira's Avatar
That does look simple. Great write up.
Old 04-16-07, 11:04 PM
wushuboy
wushuboy's Avatar
thanks for the right up javy.. this'll come in handy.
Old 04-17-07, 12:33 AM
Hartawan
Former Vendor
Hartawan's Avatar
Originally Posted by javyLSU
...several trips to the drag strip and mountain/canyon runs...
ooo, where do you go? Angeles Crest?
Great write up
Old 04-17-07, 12:45 AM
Tchan1
Tchan1's Avatar
So resurfacing of the rotors aren't required?
Old 04-17-07, 01:37 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
No. Not unless they are damaged or deeply scored. Resurfacing is just a quick way to get new rotors on the car.
Old 04-17-07, 02:04 AM
ULTiMaX99
ULTiMaX99's Avatar
great diy write up javy! now someone needs to do this for the 250 hahah. btw, what camera did you use?
Old 04-17-07, 03:26 AM
WhatYaGot
WhatYaGot's Avatar
Thanks for taking the time to share this with us!
Old 04-17-07, 06:27 AM
Tony59blue
Tony59blue's Avatar
Great write up Javy. I have 16k miles on my car now. Most of them where highway miles so my brakes are still doing great. I'll have to remember this DIY when i get mine changed. Thanks
Old 04-17-07, 06:51 AM
IS350jet
IS350jet's Avatar
That was a great wright up. Thank you. I noticed you used the original OEM pads instead of the new OEM less dusty pad. Any reason for that decision?
Quick Reply: DIY: IS350 front brakes (w/o removing caliper)
