2007 ES350 Coolant Flush
Old Jun 4, 2026 | 06:08 AM
June1978's Avatar
June1978
Default 2007 ES350 Coolant Flush
Getting a coolant flush done this weekend. Should the thermostat be swapped out to for maintenance purposes? My tech said no need.
Old Jun 4, 2026 | 07:30 AM
Thermostat is mileage dependent, plus how many heat cycles it goes though. Around 150,000 miles is when I consider replacing it. Never use anything but a genuine Toyota part 90916-03133 here you'll regret it. Hope your tech is using Toyota Super Long Life coolant not some generic "good" enough product.
Old Jun 4, 2026 | 08:08 AM
June1978's Avatar
June1978
Looking at the Lexus records, it's never been replaced. Previous owner only took it to the dealer up until my ownership starting in 2021. I have the genuine part but he said leave it alone. If it's not causing issues, no need to replace- but I'm at 240k
My tech is a Toyota guy who works at the dealer. Does side work here and there. Basic maintenance stuff like oil, fluids, brakes etc....nothing major.
Old Jun 4, 2026 | 08:22 AM
That's an impressive run for a thermostat.
Old Jun 4, 2026 | 09:31 AM
June1978's Avatar
June1978
Yeah, if it's been replaced, there's no record of it. and I don't know how to tell. I'll leave it alone for now.
"if it ain't broke, don't fix it".
Old Yesterday | 07:32 AM
Quinten's Avatar
Quinten
If engine coolant temp comes up to normal within a few minutes and stays there (steady) while driving it is functioning properly. If it takes longer than a few minutes to reach normal operating temp, then you would want to replace it.
Old Yesterday | 10:20 AM
June1978's Avatar
June1978
Yes, it's working normally.
My gauge is almost at the half way point- maybe a few millimeters before the midpoint. I don't think it ever sat exactly in the middle.....
Bernardc
Feb 19, 2025 08:32 PM
Elmi
Feb 13, 2025 05:03 PM
goat430
Feb 3, 2025 11:51 AM
wr332
Mar 3, 2023 05:52 AM
Arpadf189
Jan 3, 2019 06:00 AM
