Help Diagnosing Whirring Sound 2002 Lexus LS430
Whirring sound near front area of engine that I can't figure out where it's coming from. Was hoping a different set of ears or anyone familiar with this noise on the LS430 can help me figure it out before I pay for a diagnosis at a mechanic. (broke college student)
Work I did before was install oil pan & transmission spacers, and an oil change. During installation of the spacers, existing power steering leak must have flexed making the leak huge. At the time I thought it was old oil pooled from an oil leak I used to have that spilled by moving the engine so I started up the car to clean and it sounded normal. It only started making the whirring noise the next morning and that's when I saw the huge pool of ps fluid. I don't know if ps fluid got on the alternator but a bit got on the serpentine belt (Ran a test, don't think that's the cause).
What I fixed/tested already:
-Replaced power steering reservoir, suction hose, and hose for return line.
-Made sure to turn wheel to get rid of any air and topped the fluid as it dropped.
-Don't see loose panels/parts vibrating and engine oil/ps levels are good.
-Took off serpentine belt and started car. Whirring still there but maybe a bit faster and slightly higher pitched?
Notes:
-Loudest near serpentine belt area/drivers side wheel.
-Whirring speeds up with rpms.
-Turning the wheel does not affect the sound.
What I believe it to be:
1. Timing belt (pretty close to where it's loudest)
2. Power Steering Pump (maybe fried by starting it w/o enough fluid but idk how a failing ps pump sounds)
Notes:
I have a similar whir since my timing belt change 7 months ago. But only at speed, not apparently rpm related. 40 mph most audible, fixed pitch. Changed front tires for unrelated reasons, nio difference. It is not loud, but I know my car... any ideas, please? I'll bring it in but the place that did the belt is never good with "soft" issues.
frankheat
Jul 3, 2020 02:40 PM
