OBD Scanner
Old May 12, 2026 | 05:57 PM
hymie747's Avatar
hymie747
1st Gear
Default OBD Scanner
Does anyone know of a decent OBD Scanner which will also do ABS Bleeding for 2007 LS 460
Old May 14, 2026 | 01:50 PM
BB9's Avatar
BB9
I think you need Techstream software or equivalent for this kind of work on LS 460. I might be wrong, but regular OBD scanner might not be good enough for it.
Old May 15, 2026 | 05:52 AM
dan25man's Avatar
dan25man
I agree, I have an innova 5610 and a computer with techstream. The innova 5610 is great for seeing live data but it can't access any special lexus functions. Basic evap system test and alternator load testing, but not specific to the LS460. I'd use the advanced search function in the forum. I think "think" there's a way to trick the system without throwing a code but I forget if it requires a paperclip to jump lears in the OBDII port, or you just have to bleed really slow as to not throw off the computer. I'd search for "Brake bleed" and see what you can find.
rmak
Mar 28, 2023 02:41 PM
dadopee
May 3, 2016 06:35 PM
GFerg
Oct 11, 2006 10:31 PM
Eddie80
Oct 20, 2005 05:48 PM
