Evap Mystery
All; Recently bought a 2005 ES 330. After about a month, got an engine light, which tested for Evap codes 0441 (Incorrect Purge Flow), 0442? (Evap Vent Valve), and 0456? (Large leak). So, I replaced the Purge valve, and in doing so, found and replaced a bunch of brittle vacuum hose under the hood, including a broken line going back to the Evap canister. Also replaced the gas cap. Now I am just getting the 0441 (Incorrect Purge Flow) code. All lines under the hood are routed according to the diagram, and are viable. Any ideas?
