What’s the length of the LS460 dipstick?
Old Apr 4, 2026 | 07:24 PM
DmitryLS430's Avatar
DmitryLS430
Default What’s the length of the LS460 dipstick?
Tech displaced dipstick (don’t ask); Ordered a replacement OEM dipstick, want to check the oil level before the part arrives. probably will use a wire clothes hanger. How long is the OEM oil dipstick?
Many thanks!
Old Apr 5, 2026 | 05:58 AM
Dean2's Avatar
Dean2
Many thanks!
Your info shows you have a LS430, they aren't the same length. Do you really mean LS460. If I was at home I would go out and measure mine for you. Hopefully someone can help.
Old Apr 5, 2026 | 06:36 AM
DmitryLS430
Just bought a 2010 LS460; had it delivered from the South here. Dealer’s photos show dipstick in place; it’s now gone. They probably have it, but it’s the Easter weekend.
I’m hesitant to drive the car, not having checked the oil level prior. As I wrote above, I ordered an OEM dipstick.
So, how long is the LS460 engine oil dipstick?
Old Apr 5, 2026 | 06:38 AM
Gerf's Avatar
Gerf
Is it RWD or AWD ?
Old Apr 5, 2026 | 07:01 AM
Gerf's Avatar
Gerf
This is an AWD dipstick, located towards the right rear of engine. May or may not be the same length as RWD...did you look around the engine compartment to see if it just missed the tube going back in ?
Old Apr 5, 2026 | 07:31 AM
DJWLDW's Avatar
DJWLDW
A 2010 RWD LS460L's dip stick is 35 and a quarter inches long tip to tip. Passenger side front of the engine.
Dennis
Old Apr 5, 2026 | 08:30 AM
DmitryLS430
Thank you all !!!
It's a RWD. Oil was changed just over 100 miles ago, according to dealer records. I'll go look for that dipstick now.
Old Apr 5, 2026 | 11:08 AM
DJWLDW's Avatar
DJWLDW
pull off the engine cover and see if it's under that.
Dennis
Old May 29, 2026 | 08:37 AM
Dean2's Avatar
Dean2
Did you ever find your dipstick?
Old May 29, 2026 | 10:36 AM
DmitryLS430
I did. Also had to change the radiator + hoses, plugs and did a complete brake job. Transmission shifted a bit harsh, replaced transmission fluid, now it drives like a new car, aside from the noisy a/c motor and the yellow-tinted touch display screen (I read that these can be sent out to be rebuilt). The a/c motor replacement is probably at least $1000.
Old May 29, 2026 | 10:47 AM
1SICKLEX's Avatar
1SICKLEX
CL Community Team Leader
25 Year Member
pause
lol
Old May 29, 2026 | 12:09 PM
dlbuckls10's Avatar
dlbuckls10
The touch screen can be changed to blue in your screen settings. Or was this yellow tinted screen caused by fading, wear and tear over the years?
Old May 30, 2026 | 11:21 AM
Uhsstudent's Avatar
Uhsstudent
My 07 ls460L RWD just went over 100k miles. It does have a lil lurch to the shift sometimes especially from park to drive. Do you think a trans fluid replacement would help those symptoms? Or should i have it done at 100k either way?
dyeem138
Build Threads
Jun 10, 2025 07:29 AM
Firemoth
Nov 30, 2024 12:31 PM
Richardgil
Oct 28, 2021 07:06 AM
frededvm
Sep 27, 2007 09:08 AM
