ISF 750whp partout.
For SaleEngine - Power Adders
Price
$1,000,000• OBO
- Location Milwaukee, WI, 53221, USA
- Condition Used
Description:
The beginning of my mods only partout. RR (latest V2) engine mounts with brackets. SOLD
Figs solid stainless steel trans mount with bracket. $150 + shipping.
HighSpark Japan premium ignition coils(x8), spare NEW (1) coil included. SOLD
Stage 1 RCF trans. 11k miles. Holds 750whp+ $2,000 + Freight. I'll discuss with serious buyer what's modified on it. SOLD
I also have a RR racing C38R-122 kit for sale with complete E85 fuel system/ radium surge tank/Bosch 980 port injectors/radium fuel pressure dampener/ ISF 525lph fuel pump/all custom 6AN lines. Message me to discuss! $13k obo
All items are interchangeable fitment between the ISF & RCF and I believe everything is the same on the GSF & IS500.
**As I get more time to pull parts I'll update this thread with what's available so check back often!**
Another item for sale.
Elvin Wong carbon fiber steering wheel.
Light use. Maybe 3k miles on it. Very clean - like new.
$600 + shipping.
Anodized black. 5k miles. $400 + shipping.
Alternator, Water pump, Oil Scavenger pump.
These are stock size so you can run whatever belt you want.
No bolts included - I used loctite with aluminum bolts -which helps shed further weight but essentially makes the bolts one time use due to thread deformation.
((RR crank pulley is not for sale - included with the SC kit only. ))
$450 + shipping.
Setrab (Series 6) 25 -row oil cooler with Derale Hypercool Fan.
5-PIN RELAY & WIRING INCLUDED.
Attached to modified front crash bar.(INCLUDED)
*Requires washer resivour delete*
*Requires bumper modification*
I ran this paired with an additional 25 row cooler(in series) that was buried with "dirty" air.
With both coolers I could control fluid temps via switch and keep them below ~165°F pushing the car hard (700-800whp @ WOT).
Cruising I could get temps to 140°F.
I spent some time designing this, nearly everything is riv-nuts so it's a quality piece and easily unbolted for modification/repair/maintenance/ etc.
HEAT kills transmissions.
Very clean cluster, ran this for 3 years and 8k miles.
Dealers cracked down on people cluster swapping so these are super hard to get.
$1200 + shipping. SOLD
