AC issue is forever ?
Hello all, I never got to use my AC in 4 years after I got my car (Im the 2nd owner). It's my 3rd AC compressor, which is not smth cheap for sure. The replacement was done today , and it was blowing like 44 F and it was running great. Then blowing temperature raised to 77F. Diagnosed it , and got codes B1424 and B1421 under AC, cleaned them, got the car under the sun and AC worked again and worked for 30 mins steady. I drove the car out , and the temp went up again while driving. Dunno what to do anymore, I swear I'm so disappointed just because of my AC issue for years
Well yeah, it works for 4-5 mins and temp goes up little by little. If I turn it off , and try again after couple of hours its again cold. I got no clue what light sensor has to do with AC tho
3rd compressor is terrifying to me. Even a second compressor in 2 years/1 year. Yikes!!!
What happened to each or them? Did they grenade, lockup, or just contaminate the system?
These are closed systems, anything left behind will kill a new compressor. Typical actions after compressor failure are high pressure line replacement, condenser and dryer replacement, clean evap core (replace is best), replace all contaminated lines...
Assemble, pull down for 2 to 4 hours, verify no leaks, then fill correct weight of refrigerant.
OP I didn't look up those codes but do tell exactly everything you know about its service history.
Have you been installing OEM compressors? Have you replaced the condensor? Has the system been injected with UV dye to trace leaks? Have the schraeder valves been replaced? Was a leak-down test performed after replacement for at least 15 minutes to check the system? There is a lot going on in that system and multiple vectors for issues.
Codes were about Solar sensor circuit error. But it was showing as AC error. I don't know why I suspect the cabin temp sensor, I discovered yesterday that it has a lot to do with AC, but still dots are not connecting to me. Solar error under AC, working when on P and it generally works whenever it wants
First one was the original one , that didn't worl from day 1. Cant remember exactly why we got to changing the compressor. We got a 2nd one , OEM and used of course, and it worked for 1-2 days, then valve wasnt opening at all. We swapped valves , and both compressors still didnt work. Now ir works when I start up the car, and when it's on P. Whenever I start driving it starts warming up, If I stop for 5 mins or smth, It starts to cool down, noticed just today. No leaks so far, had same amount of ref after a year.
Also, OBD Fusion App reads some AC components. In my tundra i can read evap core temp sensor. It may be helpful when diagnosing.
Are you saying it blows cold on the highway?
Take note of what fans are working. Max cool should enable both fans. Also watch the hub of the compressor and see if its cycling. i.e. the belt will always turn the outer pully, its center hub we are concerned with.
Thats the thing that its not cold when Im driving. Its cold If I just start up the car or If I drive and park the car and wait for like 5-6 mins and it gets cold. Well driver side fan works even without AC , I'll check how they behave when AC is on. I read today with Launch and Autel and both apps said no issues with AC at all. I cleaned up my cabin temp sensor as well just in case , but I suspect that it misses smth, didn't have anyone here that knows for sure if thats the temp or my gut is right
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/1500x2000/img_8724_ddf91ceb88a8bcac608dbd121a37b3df83bf009c.jpeg)
websurfer
NX - 2nd Gen (2022-current)
21
05-08-24 09:05 AM
