electrical issues after alternator replaced
hey so my alternator packed it in two days ago so i swapped it out and now i have no windows locks steering tilt sun roof taillights and my airbag light comes on
i figured maybe deflective alternator so i warrantied it and still nothing I've swapped out the fuse box under the dash as my relays were buzzing and i also swapped my anti theft module well i was under their
any ideas or something i should try?
Hello,
What's the mileage on the car?
What alternator did you get as a replacement?
Did the old alternator just stop producing power at some point, or was it causing Overvoltage in the system?
It looks like you blew one of the Fuses for one reason or the other, here is a Fuse Diagram for your car, check ALL the fuses using the Test Light, paying especially close attention to the 30A POWER Fuse, as it links all the systems you mentioned.
Hope this helps and best of luck!
Hello I just hit 290,000km
tge only alternator I could get was a acdelco and I had it on my other car for a week before I pulled the motor and it worked perfectly fine
I checked the fuses and they all appeared good I’m going to go re check all of them pretty soon and update you thank you for the help
Butterjamtoast
14
04-28-24 05:30 PM
TitanLexus
04-23-22 05:44 PM
Gundown64
07-20-14 04:08 PM
