IS 500 Threads Conversations specifically about the 2022+ IS500 models.
is500 wheel stud swap with spacers installed.
Old 04-30-23, 12:40 PM
OCJACKAL
OCJACKAL's Avatar
Default is500 wheel stud swap with spacers installed.
This took about 45 minutes. It was actually really easy. wheels look way better with them being pushed out the 15 and 20 mm
Front driver side
Rear driver side.
Rear drive side top view
drive side front
driver side front
driver side rear
Old 04-30-23, 12:48 PM
95bat
95bat's Avatar
Received 1,289 Likes on 665 Posts
Good work! 👍
Do you plan on doing PPF as well? That bit of tire sticking out will surely fling stuff down the side of the car.
BearWithMe (09-05-23)
Old 04-30-23, 01:18 PM
OCJACKAL
OCJACKAL's Avatar
I actually have it on the front hood, fenders, bumper and mirrors, but might have to add it to the rear bumper too... I dont thing it sticks out to much, maybe just a little by the lower side of the bumper
Old 05-01-23, 04:24 AM
wthrman2
wthrman2's Avatar
Received 3,671 Likes on 1,780 Posts
OCJACKALL - I am not usually a big fan of wheels being pushed out and such but this looks subtle but enough to make it look a bit more mean - Not sure I like the new lug bolts but could just be the angle of the pic.
Speaking of being mean, you shouldn't give your toes an atomic wedgy!! That looks painful and nasty (lol)
Old 05-01-23, 07:21 AM
OCJACKAL
OCJACKAL's Avatar
Smile
[img]images/icons/icon10.gif[/img]BAHAHAHA, Man, why you gotta do me that like! LOL!! I ran out to take a pic and those sandals were at the door so i went with it! I meant to crop my foot out cause I thought something like this could happen [img]images/icons/icon7.gif[/img] I definitely prefer the look with the spacers, especially once I lower it. I am still trying to decide which springs to go with. I want to hear what peeps think about the Swift springs on an actual IS500....
wthrman2 (05-01-23)
Old 05-01-23, 07:06 PM
SavFD3S
10th Gear
SavFD3S's Avatar
What studs and nuts did you go with and do you happen to have a link?
Old 05-01-23, 07:45 PM
OCJACKAL
OCJACKAL's Avatar
this is what I bought. I got them from https://motorsporthardware.com/contact-us/
If I was to do it again, I might get 10 of the studs in 82mm or so, I get a full 7 turns on the ones I have, but wish there was a a couple of threads of the stud sticking all the way out of the lug nuts like the front is
Old 05-01-23, 09:01 PM
macmaster
macmaster's Avatar
Received 1,954 Likes on 1,046 Posts
Appreciate the honesty. I did notice your studs were a little sunken in relative to the nuts.
Old 05-02-23, 03:45 AM
wthrman2
wthrman2's Avatar
Originally Posted by macmaster
did notice your stud was a little sunken in relative to the nuts.
Isn't that a medical condition? (LMAO)
OP - I see what you mean but the look isn't that bad TBH
Old 09-05-23, 10:26 AM
TipsyTonio
TipsyTonio's Avatar
Received 2,271 Likes on 1,045 Posts
What wheel spacer from H&R did you use? I can't find a single 60.1 center bore spacer with 14x1.5 threads. Only 12 x1.5. Thanks
Old 09-05-23, 12:16 PM
Pittsy
Pittsy's Avatar
When I had my RC, I was begging to be able to have wheel bolts instead of studs, since I tracked the car, studs were a wear item. Here everyone is converting back to studs!
I see how much less convenient wheel bolts are, but man the pressed in studs that the older knuckles used suck to change out. Requires pulling the rear hubs off. I guess these would be a lot easier to change.
TipsyTonio (09-05-23)
Old 09-05-23, 01:29 PM
cp2
cp2's Avatar
i'm doing some research on studs. not planning on using spacers, so i'm wondering if i should go 44mm or 64mm. anyone happen to know the length of the oem lug bolts? any help would be appreciated.
Old 09-05-23, 01:30 PM
TipsyTonio
TipsyTonio's Avatar
According to my research, the THREAD length of the OEM bolts is 27mm. Idk the overall length.
Old 09-05-23, 01:33 PM
cp2
cp2's Avatar
that's perfect! that's what i should've asked, thread length. so i should be good to go w/ 44mm. thanks @TipsyTonio
Old 09-05-23, 01:34 PM
TipsyTonio
TipsyTonio's Avatar
No worries. For reference, ****** includes 42mm bolts with their 15mm spacer and 47mm bolts with their 20mm spacer. That solidified my 27mm initial calculation for stock.
Quick Reply: is500 wheel stud swap with spacers installed.
